Technical Cast intake flaking pieces internally
Discussion in 'The Hokey Ass Message Board' started by Dan Yager, Nov 13, 2021.
  1. onetrickpony
    onetrickpony
    from Texas
    I used to see the same problem with deteriorating cast iron on Ford FE motors a bunch. The heat riser valve on the exhaust manifold would stick and that crossover passage would see a lot more heat than usual. Sometimes they would burn all the way through to the valley area
  2. Yup, I had a 390 intake do that. I was cleaning things up ready to reinstall and right below the carb I could see the floor of the plenum was misshapen. A few light taps with a hammer and punch and I was right thru into the exhaust crossover. I tossed that manifold and put a different one on. Should it come to that, it might be a little tougher to find one for an old baby hemi. :(
    Dan Yager likes this.
  3. Ebbsspeed
    Ebbsspeed
    No, you don't need the heat riser. All it does is forces exhaust through the crossover so that the carburetor and intake vaporize the fuel mix more efficiently from a cold startup. The heat riser has a bimetal spring that opens it after it warms up a bit. Leave the heat riser off. The engine may be a little cold blooded and take a couple minutes to warm up, but that's the only change you would notice.
    loudbang, SS327, alanp561 and 2 others like this.
  4. Dan Yager
    Dan Yager
    Center of the Galaxie. If it came down to it, I also have a 4bbl manifold I could use. This all jus fortifies the fact I’m not getting rid of any parts I have. They are hard to come by
    Center of the Galaxie and SS327 like this.
  5. Dan Yager
    Dan Yager
    Ebbsspeed. Perfect. I shall leave the riser off
    loudbang and indyjps like this.
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    A crossover pipe is not needed to use a heat riser , how would you suppose an engine with factory dual exhaust would work . the exhaust from the heat riser side is forced through the intake heat port , thus heating the manifold .
  7. Dan Yager
    Dan Yager
    Perfect because I’m going to run dual exhaust. Thank you
    SS327 likes this.
