cast iron BW 4-speed??
Discussion in 'The Hokey Ass Message Board' started by chubbie, Mar 14, 2012.
  1. chubbie
    chubbie
    we went "pick'n" yesterday, don't know how we found this guy. he has a lot of "stuff"!! Cars were mostly mid "60's fords. some 40's dodge ect. any way he had several pilles of transmissions, and i can usually pick out what they are. he had a cast iron 4 speed that looked like a borg-warner T-10. it had been painted silver and most of the paint had flaked off. there was a aluminum shifter mount like the comp plus hurst shiffters used. it looked like a GM bolt pattern and tail shaft.
    did GM make a cast 4 speed with the reverse mech. in the tail shaft housing?? what would it be worth, does someone want these for early 4-speed restos??
  2. squirrel
    The iron case T10 was what Chevy used before they invented the Muncie. They can be valuable to some restorers, depending on what model it is.
  3. Topless Ford
    Topless Ford
    Pretty sure I had a cast iron saginaw out of an early 70s Chevy. It was nothing special but had a deeeeep first gear.
  4. Hotrodbuilderny
    Hotrodbuilderny
    I had a cast iron case T10 in my first 63 Nova back in 71.I was offered a new T 10 by the performance Chevy dealer parts guy back then.He wanted it for his 62 corvette race car.Cast iron case aluminum tail housing.
  5. Andy
    Andy
    A friend who is a Corvette enthusiast got extreamly happy when he found a iron T-10. He thought it was a 57 vette only deal. I never had a vette or a T-10 so have no clue.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Check it over for casting dates. It could be a late '50s T-10, or it could be a cast iron over the counter replacement transmission. I've got one with 1980 dates on it.
  7. Hnstray
    Hnstray
    from Quincy, IL
    I have a cast iron T-10, original equipment, in my 63 1/2 Falcon Sprint......of course it has the Ford bell pattern......
    Ray
  8. cm30
    cm30
    I think GM in the late 70's early 80's used super T10 4 speeds. 903 was all aluminum and 904 was cast main case and aluminum tailshaft. $400-500 for one in ok shape. Look at the output shaft, super T10 should be big like a th400 and t10 will be small like a sag.
  9. jrlemke
    jrlemke
    With the silver paint, it might be a Studebaker. 61 & early 62 used a C.I. T-10 with the Chev pattern. Check the input shaft, Stude will have a longer pilot with a larger dia. -Jim
  10. chubbie
    chubbie
    Its a all cast iron transmission and the output shaft looks like a standard chevy. the front bolt to the bell brakets, look like they have less braceing or gussets than the aluminum transmissions do.
  11. starliner62
    starliner62
    I have a cast iron T-10 out of a Stude. It's supposed to be a close ratio trans.
  12. junkyardog101
    junkyardog101
    from NM
    Hello, I am new to the Forum but with several searches I found this to be a very knowledgeable collection of members.
    With that said, I found this thread and have a transmission I have only partially ID'd. From what I gather its a Borg Warner T-10, made it 1978. Front and back are cast Iron center plate is aluminium. 26 spline in and 27 spline out. Here are a couple of pics...[​IMG][/IMG]
    [​IMG][/IMG]
    Any ***istance in helping me figure out what I bought will be greatly appreciated.
    JYD
  13. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
  14. junkyardog101
    junkyardog101
    from NM
    Thanks! That helps a lot, there are a few odd items left to figure out though. If I read everything right, my trans is an aftermarket super T-10, but I counted only 27 splines on the output shaft.... perhaps I need to recount. I also noticed that when looking at photos I never saw another T-10 with the multiple mounting holes on the tail shaft housing like on mine. I suppose this is related to the fact that its aftermarket.
  15. I have a cast iron T 10, I'm told it came out of a Cosworth Vega. Anybody know if that's that what they ran?
