Hot Rods Cast Iron Ramhorn fix?
Discussion in 'The Hokey Ass Message Board' started by Bad Bob, Jul 13, 2022.
  1. Bad Bob
    Bad Bob
    from O.C. Baby
    Is there a way to fix a 1/4"-3/8" hole in a cast iron ramhorn exhaust manifold? Just need a fix til I can get another pair.
  2. Suicide77
    Suicide77
    from Utah
    Can you drill it out and tap it for a bolt/setscrew?
  3. Is it a hole ?
    do you need to p*** a bolt through it ?
    If it’s just a hole you can braze it or even jb weld works ok sometimes
    SS327 likes this.
  4. K13
    K13
    porknbeaner likes this.
  5. Ive silicon brazed em —Tig
    And nickle —-stick
    Br***—torch
    SS327, porknbeaner, ottoman and 3 others like this.
  6. Bad Bob
    Bad Bob
    from O.C. Baby
    I thought about doing that, cause it's so small. Not like it's a crack.
  7. Bad Bob
    Bad Bob
    from O.C. Baby
  8. Bad Bob
    Bad Bob
    from O.C. Baby
    It's about the size of a pencil eraser. 1/4"ish... The bad part is, i'm getting fumes when stopped.
  9. Bad Bob
    Bad Bob
    from O.C. Baby
    I have to find another set, that will clear my steering, so this will be temporary. Nobody will see it anyways...
  10. I have tig welded with bronze filler rod with great success.
    Just need to thoroughly clean the area and pre heat before welding.
    Vic
    anthony myrick likes this.
  11. Dan Timberlake
    Dan Timberlake
    A picture would be helpful.
    I wondering how a hole could even be punched in a cast iron manifold.
    deathrowdave likes this.
  12. Bad Bob
    Bad Bob
    from O.C. Baby
    Why....never seen a hole before? Didn't say it was "punched" in it. These manifolds are really old, so it's just worn in.
    SS327 likes this.
  13. indyjps
    indyjps
    :) People are trying to help. If it's a hole with no crack, drill it out - tap it- throw a plug in it. If it's a hole with a crack, drill the ends, drill and tap, put a plug in it, this will likely open up the crack - so braze or weld up the crack and the plug.
    If it needs welded or brazed, depends on what equipment you have available Anthony Myrick covered the options.
  14. Bad Bob
    Bad Bob
    from O.C. Baby
    Easy partner....It's a simple question. 1/4" hole in cast iron exhaust manifold. Not, misfire in my LS2....lol!!
  15. G-son
    G-son
    from Sweden
    Seen lots of holes, with lots of different shapes, sizes, causes, locations and so on, and this means different methods are suitable for fixing the different kinds of holes.
    It's like when people ask how to remove a broken bolt, there are countless ways to do it but most of them will be less than ideal and some quite unsuitable. You have to choose the right method for the cir***stances, if those are unknown it becomes impossible to make an informed choice. Sometimes you heat it red hot with the torch, sometimes plastic parts in the area makes that a really bad idea...
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Moriarity likes this.
  17. Bad Bob
    Bad Bob
    from O.C. Baby
    The obvious fix would be braising it...but it's temporary, so just putting a bolt in it is probably the easiest fix. And, it's NOT like removing a broken bolt. That takes more skill and planning. This is more like a zip tie on your carb linkage, hahaha
  18. Bad Bob
    Bad Bob
    from O.C. Baby
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Don't use cutting oil then.
  20. Bad Bob
    Bad Bob
    from O.C. Baby
    haha....nope!
  21. Dave G in Gansevoort
    from Upstate NY
    What part of the world are you in? I've got a pair from old mangy, a 327. I'm not using them and if you pick them up, they're free. I'm not shipping them however... call me lazy!
    G-son likes this.
  22. Bad Bob
    Bad Bob
    from O.C. Baby
  23. What are you looking for Bob, I might have something. Center dump 2" or 2.5", angled truck or 265 style?
    If nothing else, I used some manifold putty on some headers that lasted pretty well.
    Desoto291Hemi likes this.
  24. Bad Bob
    Bad Bob
    from O.C. Baby
    YOU'RE LAZY! HAHA
    SS327 and Dave G in Gansevoort like this.
  25. Bad Bob
    Bad Bob
    from O.C. Baby
    They're angle dump. The hole is right next to the top bolt. P*** side is good... Driver side is haggered from grinding on it to clear the steering. (not by me!)Probably why it burned a hole .
  26. Last edited: Jul 13, 2022
  27. Bad Bob
    Bad Bob
    from O.C. Baby
    Drivers side angle dumps back. It's a 1957, 283. I'll be at the Hotrods on the Tarmac on saturday.
  28. I'll look tonight, I'm going to try to make it to Lyons that Sat after the swapmeet.
    If space is at a premium and total performance isn't needed might go with some 265 manifolds....but then exhaust pipe work is needed.
    KenC likes this.
  29. Bad Bob
    Bad Bob
    from O.C. Baby
    I NEED ONE THAT DROPS OFF BEHIND THE TWO MIDDLE CYLINDERS.
  30. BamaMav
    BamaMav
    from Berry, AL
    I welded a crack and hole in the manifold of my 8n tractor. Used my flux core mig. Even welded the flange up and ground it back flat where it had leaked and cut the flange. Didn’t do anything special, just welded a little then let it air cool, then welded some more. Been on there a couple of years now, still no leaks or new cracks. YMMV
