1952-59 Ford cast iron ?
Discussion in 'Off Topic Hot Rods & Customs' started by the gormandizers, Jan 15, 2010.
  1. the gormandizers
    the gormandizers
    from France
    Hello
    I wondered if the rear axle on my ford 1954 was in cast iron or iron?
    I have to weld on the system "Weld-On 4-Link" on this last one and if it's in cast iron, I can't.
    Thanks,
    Rémi.
  2. mjlangley
    mjlangley
    from SE MI
    Most likely the center section (where the ring and pinion and differential are) is cast iron, and the axle tubes (where you would attach spring perches or 4-link/ ladder bar brackets) are steel...
