Technical Caster 1936
Discussion in 'Traditional Hot Rods' started by 3wmike, Jan 24, 2022.
  1. 3wmike
    3wmike
    What is the right caster angle, or what do you suggest ?
    I have split the wishbone to about 8 inches between the rod ends and they are mounted at about the same height as original and then my caster will be about 0-1 degrees
    Thanks Mike
  2. Phil P
    Phil P
    For a street driven car 7 degrees.
    Phil
  3. 3wmike
    3wmike
    Fine Thanks
  4. gary macdonald
    gary macdonald
    With Radial tires and high speed I aim for 3-5 degrees with 1/8” toe
    chryslerfan55 and hemihotrod66 like this.
  5. Ron Plumlee
    Ron Plumlee
    Agree with Phil 7 degrees good starting point....depending on your steering setup you may want to play with caster a bit, you will be surprised at the difference in arm strength (your arms) required to turn at 4 degrees versus 8, not to speak of straight line stability....easy to play with .
    hotrodjack33 and chryslerfan55 like this.
  6. hemihotrod66
    hemihotrod66
    To much caster will give you low speed "death wobble"....I like between 3 and 5 degrees...
  7. 3wmike
    3wmike
    Now I´ve reached 5 degrees, I might will try to raise it to 7 degrees after I read your comments
    Thanks
  8. oj
    oj
    I don't set the caster with the bones/radius rods, they are meant to support not initiate. Caster is set at the spring mounting pad inside the crossmember. If you remove the spring you can stick your hand up in there are feel the angle, it'll be taller at the rear. The reason Ford did it like this is to eliminate binding at the spring mounts, if the spring pad were 0 degrees and the radius rod 7 degrees they will be all bound up and break on the dirt roads, no to mention a total ***** to ***emble. I think I've seen a supplier or two sell spring mounts that pivot for those situations.
  9. X-cpe
    X-cpe
    The spring mount pad should slope down front to rear. Putting rake in a car takes away positive caster. If the back of the pad is higher than the front you would have negative caster.
  10. Mr48chev
    This is the Ford alignment page out of my 1946 Motor manual.
