Technical Caster Question
Discussion in 'Traditional Hot Rods' started by NB141FD, Dec 15, 2023.
  1. NB141FD
    NB141FD
    Trying to understand Caster a little better. I have split wishbones on a 30 Model A. My question: What is my Caster? If I measure 10° at the king pins and my wishbones are 2 1/2° below horizontal at the back end, is my actual Caster 10° minus 2 1/2° for 7 1/2° or still 10°? This ***umes that the floor is perfectly level (for simplicity).
    TIA, Tony
  2. Happydaze
    Happydaze
    But when you measure it the frame has to be at the inclination the its going to ride at, often confusingly termed 'ride height'.
    Chris
    ekimneirbo likes this.
  3. jimmy six
    jimmy six
    10* is a lot. I don’t have that much on my LSR roadster. It must go straight nice.
    Tow Truck Tom and Stan Back like this.
  4. ekimneirbo
    ekimneirbo
    from Brooks Ky
    As HappyDaze mentioned, if you have your frame sitting on a level surface, and then when you mount tires and sit the whole thing on the ground.......if it is raked, that will offset some of the "caster" you built in. The frame needs to be sitting at the same angle it will when the car is done. Some aftermarket crossmembers are designed tp provide more caster (as well as slight lowering) and also angled to prevent spring bind as the spring moves .
    Note: corrected the word "camber" to caster ..........had a brain fart there.
    Thanks "@twenty8" for catching that.
    05snopro440 likes this.
  5. NB141FD
    NB141FD
    Thanks Happydaze the car is done, this measurement is at ride height completely loaded (engine etc...)
  6. NB141FD
    NB141FD
    I was trying to get to 7°. I can't raise the wish bones at the rear any higher to reduce the Caster. It drives pretty good so I think I'll just accept 10°.
    Kevin Ardinger likes this.
  7. Automotive Stud
    Automotive Stud
    I think I'd rather have too much than not enough. If it's at 10 and it drives good I'd be happy.
    2OLD2FAST and 1971BB427 like this.
  8. wheeltramp brian
    wheeltramp brian
    I put 10 in every Straight axle car I do as it makes it track perfect at eighty five going down the highway.
    big duece, jimmy six, vtx1800 and 2 others like this.
  9. clem
    clem
    10* measured in my sedan, original wishbone.
    7* in the other one, split wishbones
    Both drive okay !
  10. twenty8
    twenty8
    Good info, but you need to change the word "camber" to "caster" so people don't get mixed up.
    Budget36 likes this.
  11. NB141FD
    NB141FD
    Thanks for the info guys.
  12. twenty8
    twenty8
    10* in a light car would be ok. Caster makes you actually lift the car's m*** with the steering wheel as you turn left or right. The m*** lowering itself is what gives the self- centering steering effect. If the car is heavier, a little less caster is a good idea.
    big duece, clem and leon bee like this.
  13. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Correction made and thank you for pointing out my mistake. I do strive to be accurate in what I post and appreciate when someone helps me correct some of the brain farts that happen.:)
  14. 1971BB427
    1971BB427
    from Oregon
    I set axles on cars under 100" wheelbase closer to 10 degrees. But over 100", and especially more common around 112"-116" wheelbase, a 6-7 degree angle works just fine. I have 10 degrees in my 89" Austin, and 6 degrees in my '39 Chev coupe. Both drive equally well, but the Austin does not back up as easily with wheels cranked hard like the '39 does.
  15. dirt t
    dirt t
    THERE IS ALSO ADJUSTABLE SPRING perches. Speedway #
    910-33042 eliminates binding.
  16. badsix
    badsix
    received my 6" lowered tube axle from Speedway a couple days ago. so yesterday i went to fit it to the springs to see how the width is going to work out, the spring pads DON'T work they are made for a rig with Stright frame rails and springs. the 31 Chevy has the frame and springs at a slight angle to the front. the pads fit the springs ok BUT the saddle for the axle is way off. looks like i'll have to make some, don't know what else to do.
    Jay D.
