Technical Center cap help ?
Discussion in 'The Hokey Ass Message Board' started by Jet96, Jan 17, 2015.
  1. Jet96
    Jet96
    from WY
    I just stripped down a stuck 59ab that I picked up for cheap and found this interesting... Center main had bolts and lock washers. One shouldered bolt, one non shouldered. Engine had 40 over pistons, rods all have 8ba on them. Anyway, I'm not sure whether that center main cap is the correct one or not? I can't seem to locate any thing that ID's them. Thanks
  2. 302GMC
    302GMC
    from Idaho
    If the mains aren't spun, it's the likely the right one. Feel the parting faces with the crank out.
    Hnstray likes this.
  3. Hnstray
    Hnstray
    from Quincy, IL
    ^^^^^^^you can also use an inside mike to measure and compare the block main bearing
    bores for diameter and roundness. That should reveal if the cap in question properly 'fits'
    the block.
    Ray
  4. Jet96
    Jet96
    from WY
    Thanks guys, I got the crank out, looks great. I'm guessing that the center should be studs also? I haven't had a 59 apart, just 8ba. Weird deal, the bottom end and cam looks like a low mileage rebuild but the Pistons were Seriously! rusted in. So bad that 5 of them left the outer shell and rings stuck in the bore when I drove them out. I carefully! sawed through them and got it apart without screwing the bores up. Maybe it was laying upside down, I dunno. Lotta work, but no cracks visible yet!
  5. Jet96
    Jet96
    from WY
    BTW, I've had the cylinders full of acetone/ATF for about two months! This thing was stuck!
