Center Caps For MOPAR ARTILLERY Wheels
Discussion in 'The Hokey Ass Message Board' started by lrs30, Dec 16, 2008.
  1. lrs30
    lrs30
    from Kentucky
    I'm having no luck finding center caps for my Mid 30's MOPAR Artillery wheel's any help from you guys that are running them?`I don't need expensive originals..
    I'm willing to run baby moon style if anybody knows where I can find them...
  2. 4woody
    4woody
    Ask "Wheelkid" he'll know.
  3. lrs30
    lrs30
    from Kentucky
    Curious if other years fit these as well...
  4. lrs30
    lrs30
    from Kentucky
    I think I did a while back and never heard back from him, so I did'nt want to bother him again...I will try again..Ryan
  5. scootermcrad
    scootermcrad
    You have to call him. He's too busy to answer emails or PM's.
    *****in' wheels. Who actually made those wheels? What was the sub-company? Anyone know?
  6. lrs30
    lrs30
    from Kentucky
    Motor Wheel Corp I believe thats what was stamped on them If I remember correct
  7. lrs30
    lrs30
    from Kentucky
    I hope to finish the fronts here soon and get the tires mounted and get the ch***is rolling.... And the list keep's getting longer...lol
  8. lrs30
    lrs30
    from Kentucky
    anybody else?
  9. MIKE-3137
    MIKE-3137
    i'm looking for them too, for my ford bolt pattern artillery wheels, If I find out anything i'll send it your way.
  10. lrs30
    lrs30
    from Kentucky
    Thank's..
  11. 29 bones
    29 bones
    from so cal
    hello you can use chevrolet baby moons for the rally wheel,it takes a little work just bend the wheel tabs and take a little material off the moon cap and pop it on.
    here is a pick of my ch***is,for more pics check out my web site sperlingbuilt.com
    http://[​IMG]
  12. Squablow
    Squablow
    I'm putting these wheels on my '40 Chrysler, I have a set of junk '36 Plymouth stock caps and I am cutting the center rings out of the '36 Plym. caps and welding them to the inside ring of the '40 Chrysler caps, seems to work fine, although to do it you have to have a set of original caps to cut up.
    The baldie caps on 29bones' car look really good, I'm going for more of a stock look but on a rod I like what he's got going. Although it looks like he has 17" wheels which might be different.
  13. Weasel
    Weasel
    My Budd artillery wheels take a cap which has an opening diameter of 7". There were two main types of wheels used on non Ford 1930s cars - Motor Wheel as shown above and Budd Mfg which have an open 'window' where the rim forms the third side of the window - see photo.
  14. model-a-fan
    model-a-fan
    from Kentucky
    I have identical wheels on my '31. The caps are Plymouth and I was told by the PO the wheels are early thirties Plymouth/Dodge as well. There's a place on Preston HWY in Louisville that has tons of caps. E-mail me and I'll give ya the low down.
  15. scootermcrad
    scootermcrad
    Close up of the above:
    *****in' ch***is, by the way, 29 bones.
  16. lrs30
    lrs30
    from Kentucky
    I have a set of plain baby moons from my 54 that I am not using on it. My plan was to modify them to fit as well, just seeing what everybody else has done.
    Scootrmcrad thatd a kick-*** build you have there...
  17. 2deuces64
    2deuces64
    I'm using the same wheels on my RPU. I'm using 32 ford caps. I had some junk wires (32-35) cut the mounting rings off of them and I'm going to weld to my Mopar centers. I had the Wheelkid change my hoops to 16x7 and 15x5.
  18. Dreddybear
    Dreddybear
    Dude! Thank you. I have been looking for a year...
  19. Archie
    Archie
    I have a bunch of rims but no caps. I will be needing 8-10 caps
    Do you have a link for the chevy baby moons?
    Thank You
    Archie
  20. MIKE-3137
    MIKE-3137
    Don't mean to hijack the thread, but looks like the info could be of use to everyone running artilleries, never thought about the rally caps, but I think mine have a bigger hub area than the mopar wheels. 29 Bones and Irs30, can you tell us the diameter of your wheel centers?
  21. lrs30
    lrs30
    from Kentucky
  22. lrs30
    lrs30
    from Kentucky
    My moons came from Summit racing with my chrome reverse rims for my 54
  23. 36DodgeRam
    36DodgeRam
    Looks just like the wheels I just pulled off my '36 Dodge. I've got 7 with caps. These things worth something now?
  24. lrs30
    lrs30
    from Kentucky
    Depends on the shape, some more than others and only worth something if someone needs them I guess...I will come pick them up from you...If your getting rid of them..
  25. lrs30
    lrs30
    from Kentucky
    Anbody else??? Still looking
  26. pasadenahotrod
    pasadenahotrod
    from Texas
    I believe there was a previous reference to "EXPENSIVE" originals from somebody.
  27. lrs30
    lrs30
    from Kentucky
    Oh yhea, tell me about it.. I will probably just modify a set of moons for this , unless I can find a set (INSERT BRAND NAME HERE)that fit...
  28. I will keep an eye on this thread as I am also looking for a set of center caps for the exact same wheels.
  29. lrs30
    lrs30
    from Kentucky
    OK revisiting this old thread.. Anybody have an input ?
  30. biscuit eater
    biscuit eater
    I'm using the same wheels, mine are 17". I bought a set of Dodge caps and a set of Chrysler caps close to a size that I thought would work and neither set will fit. I like the look of the Chryslers the best so I'll probably try to modify them to work. I'll let the Dodges go if they'll help anybody. They are decent drivers with red Dodge lettering straight across.
