Centering a 9" Ford Rear End??? Need Help
Discussion in 'The Hokey Ass Message Board' started by garysgun, Apr 4, 2006.
  1. garysgun
    garysgun
    I want to center my 9" Ford rear end so from the rear view it looks centered
    but the drive shaft will be off center a bit. Is this any problem? I know it would be hard on drive shaft universals but for a run around town hot rod is there really any problem? The deal is you will be able to see the rear end well. Any help would be appreciated. Also is there a degree that the front of the pig should be set at? I know that the trans and rear should be within 3-5 degrees of parallel to each other. Thanks Gary M.
  2. Mutt
    Mutt
    No problem with the offset. The driveline should be equal but opposite, with 3-5 deg. being optimum. Do a search - driveline setup has been covered extensively.
    Mutt
  3. This is funny, 'cause I need to un-center the 9" rear end under my '36 3-window so the pinion (driveshaft ) is centered. I think shortening the long side 4" will do what I want.
  4. Pro builders and home builders have been centering the rearends in hotrods for years without any problems.
  5. Paul
    Paul
    Editor
    if a guy was real savvy
    he could snag the appropriate length axle from a donor
    so's all he needed to do would be to shorten the housing
    or he could grab a rear that already has a centered pumpkin
    ..like the early Bronco..for instance..
  6. NickGee
    NickGee
    Another option, install it like it is. It works well and if this is a driver most rodders behind you will not even care. It is not that noticable.
  7. Larry T
    Larry T
    The pinion in a Ford is about 1 1/8" off center. So it should take about 2 1/4" off one axle to get it back, if the housing is centered to start with.
    I know it's a whole other deal, but I've seen racecars with the housing centered and the engine and transmission offset an inch to the p***angers side. It offsets the drivers weight and gives you a little more room for steering, pedals and such.
    Off to work.
  8. butch27
    butch27
    Never knew the early Bronco rear was centered. Worked at Ford - building them.
  9. Paul
    Paul
    Editor
    I knew the pinions were offset but didn't realize the offset centered the housing until I put a tape on one
  10. krylon32
    krylon32
    from Nebraska
    Have used 100s of housing centered rears in ch***is and have had no problems, just pay attention to your pinion angle.
