Hoping to finally get my ever-so-slightly-OT '66 Skylark straightened & painted, and am looking for some body shop recommendations. Not needing anything fancy (can't afford it), just a good, solid shop that knows older cars. On a tight budget, so cost will be a YUUUGE factor. Any thoughts?
have used MAACO body & paint services for years - check them out and see if they work on older cars at shop near you - no matter where you go have to have lots of patience - and expect the unexpected when sanding down old paint
Thanks folks. Yep, I'm going down to Bare Metal as I really want to make sure there are no surprises lurking under the layers. So far found a bit more filler than I'd like, but no rust, no patch panels, pretty clean all things considered.
I work with a old man in Mariposa that has been doing body and paint for over 63 years. He no longer paints but he still going strong on the bodywork. He is a true craftsman. I will PM you his number incase your interested.
Then for sure Maaco. If you want a nice job and not experienced, find a Professional bodyman to prep it at a under the table fair hourly rate and not try to charge a shop rate of $125 hour. have him block it ready to paint status then have Maaco shoot it.
