Technical challenge! can you spot the problem.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 26, 2025.
  1. tb33anda3rd
    tb33anda3rd
    it is under the plate, you can see it in this photo
    could be...?
    hopefully:D:cool: image0-4.jpeg
  2. tb33anda3rd
    tb33anda3rd
    I have all the parts cleaned and ready to ***emble. image1-2.jpeg bushings in the housing had no play so I left it together, but cleaned it real good.
    Tim, Speccie, ct1932ford and 2 others like this.
  3. tb33anda3rd
    tb33anda3rd
    all back together. new br*** nuts and washers, lube on the cam, fresh grease in the grease cup, pivot for advanced cleaned and lubed, wire routed away from housing [no movement on this distributor but a good habit], trimmed the fork on the condenser wire [it was capable of hitting ground] and adjusted points. image0-4.jpeg image1-2.jpeg image2-2.jpeg image4-3.jpeg
    Tim, Sharpone, '28phonebooth and 3 others like this.
  4. tb33anda3rd
    tb33anda3rd
    Tried to see if I could measure the difference in the spring of the points, for example. simply.
    I could fold the spring of the old set easily between my pinky and ring finger, which if you try to grip something that way, doesn't have a lot of strength. I couldn't fold the spring of the new points without exerting a lot of force with my thumb and fore finger. image3-2.jpeg
  5. Fortunateson
    Fortunateson
    So is the spring tension too much or are you keeping's dangling...? Gap not correct?
    Sharpone likes this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    I am quite certain that there is a spring missing from the first set and that has to be why it was running poorly. It will be great now, good job
  7. tb33anda3rd
    tb33anda3rd
    new points will be perfect , the old points were the problem, in combination with a bunch of small things. will get it running tomorrow. i also had to rebuild the starter for the truck.
    I agree that the old set was missing a spring and they were the big problem.
    thank you.
    ****ty parts and bad maintenance give point distributors a bad reputation. In another scenario a Petronics would have been put in:rolleyes: and another points basher would be born.:eek:
    Tickety Boo, Paul B, Sharpone and 2 others like this.
  8. tb33anda3rd
    tb33anda3rd
    image0-4.jpeg image2-2.jpeg image1-2.jpeg image3-2.jpeg final update:
    dropped distributor back in, set timing and took it for a test drive. truck pulled perfect and revved as high as I dared.
    55 MPH no problem
    Problem was a weak/missing spring on the points. this was allowing the points to "float" at high revs.
    There is a video on my Inst gram post showing the truck pull.
    ct1932ford, Paul B, Sharpone and 3 others like this.
  9. Aftermarket stuff is junk (new stuff). I just bought a few NOS GM and some NORS Niehoff points (and condensers), fit perfect. Both for a V8 and 6, got to test out my Milton dwell checker.
    Those look like some ****py stamped points, but the blue wire on the condenser tells me it might be Standard Ignition parts.
    Found them, new Standard Ignition points without the spring.
    DR1823
    tb33anda3rd and Sharpone like this.
  10. tb33anda3rd
    tb33anda3rd
    thanks for posting a picture of the "missing" spring ,for guys that may not have known what we were talking about.
    1oldtimer and Moriarity like this.
