Technical Challenge Using Small Base Rochesters 2G’s
Discussion in 'Traditional Hot Rods' started by James Halsey, Nov 17, 2025.
  1. James Halsey
    James Halsey
    My just completed 32 Ford hot rod has a 65 Pontiac GTO motor installed using a repro 66 OEM tripower manifold. When it was time to purchase carbs, I ended up buying small base Rochester’s. I did not know there were small base and large base carbs at the time. I ended up resorting to adapters to overcome the problem. I’ve been having poor running, fouled plugs and gas seeping from the top gasket which only has few hundred miles on it. I have tried different float levels with no luck. The engine has a Crower Thumpr cam hydraulic roller cam with a quite choppy idle and 12 “ of vacuum at idle. I changed the power valve for one with a weaker spring. No improvement. I installed a fuel pressure regulator and adjusted the idle pressure to 3.5 psi. Still not improvement.
    I finally measured the angle of the carb flanges and found them to be at -7.5 degrees from horizontal (tilted towards the front of the engine). The valve covers measure at -2.5 degrees so the manifold apparently has a cast in 5 degrees of downwards slant.
    I checked with the vendor who I bought the carbs from and he says that 7.5 degrees is too much for these carbs to cope with. So I am racking my brain to come up with a solution, I would like to stay with 3 carbs as it fits the traditional style of the car. I have considered the following solutions:
    1. Machining the adapters to reduce the downward angle to 3 degrees.
    2. Finding another manifold that will fit my heads (OE Pontiac 65 GTO 77 heads) that does not have a cast in slant
    3. Using Holly 2300 2 bbl carbs with adapters on my current manifold.
    4. Modify the motor and or the transmission mounts to tilt the front of the motor upwards.
    Number 1 is tricky, it appears I will have to remove at least 1/4” at the back edge of the adapters which are two piece totaling 1” in height. I checked with the vendor for the adapters and he was quite helpful and suggested a 1” riser that could be milled without interfering with the countersunk bolts used in the adapters. But when I acquired the risers and mocked up the setup, I felt it looked like too much of a bodge and not the look I wanted.
    Number 2 is a possible approach but there are not many aftermarket manifolds for 65-66 Pontiac heads other than the KRE Tradewinds manifold which is more of a high performance manifold. I have yet to investigate whether the KRE manifold has any downward slant cast in.
    Number 3 is also possible as there are adapters to use the 2300’s on my manifold. I’m not sure if Holly 2300 2 bbl carbs are any more tolerant of the mounting angle I have than the Rochesters however. If anyone has knowledge in this regard, that would be very welcome as I would not want to purchase another set of carbs only to have the same problem.
    Number 4 is also possible but probably only a modest amount of angle correction is likely achievable before interference with the firewall or any number of other obstacles or pinion angle considerations limit the repositioning of the engine.
    So I asking the collective wisdom of the hot rodders for help as I see no easy solution.
    I have attached pictures of the car and the engine. Thanks in advance for any help.
    A5EC61F4-51C2-42BB-8C3C-A1FCF8D37776.jpeg E0093A80-C941-4D4D-BAD2-30265545627E.jpeg AA7E5380-F523-4A8F-8A5D-A056AE06EB35.jpeg A5EC61F4-51C2-42BB-8C3C-A1FCF8D37776.jpeg AA7E5380-F523-4A8F-8A5D-A056AE06EB35.jpeg E0093A80-C941-4D4D-BAD2-30265545627E.jpeg A5EC61F4-51C2-42BB-8C3C-A1FCF8D37776.jpeg
  2. RMR&C
    RMR&C
    from NW Montana
    Engine looks like it needs to be raised a bunch in the front.
    Rodney Dangercar, Sharpone and George like this.
  3. 19Eddy30
    19Eddy30
    from VA
    Factory Oem Tri Power was designed specifically for match heads & cam shaft combo.
    Out side of OEM spec engine
    If difficult to run correct with a aggressive cam shaft ,
    Allso If not Oem using carbs in 1 carb & equal numbers in better choice the Odd numbers of carbs .
  4. Oneball
    Oneball
    This is properly outside the box, separate the water crossover from the intake and turn the intake round. No idea if it’d actually work but in theory I can’t see why everything wouldn’t line up.
    Jokester likes this.
  5. carbking
    carbking
    Option 5 - (3) large base Rochesters.
    However - exactly what carbs do you have ? A small base for a 283 Chevrolet are going to need m***ive recalibration before working on a 389 Pontiac. MAYBE you can get it work with m***ive recalibration (no, I no longer do carbs).
    Do you have an idle byp*** in the center carb ?
    ***uming you changed the spring on the power valve actuating valve, not the power valve ?
    Did someone ever tell the inboard marine manufacturers they could not use Rochesters on a greater than 7 1/2 degree manifold ?
    The adapters are not helping either.
    Check the second line in my signature block !!!
    Jon
  6. Joe Blow
    Joe Blow
    Isn't that the Quicksand Coupe the Rolling Bones/Keith finished this past summer?
    winduptoy likes this.
  7. Ratmother
    Ratmother
    IMG_2590.jpeg James - very nice looking deuce - especially with a Pontiac V8!
    Attached photo is a factory ‘65 Tri-Power on a 400 block. Center carb is small base - end carbs are large base - same end carbs as ‘66 (if I’m remembering correctly). As you no doubt learned, the end carbs are tri-power specific - no chokes and no idle adjustment circuits. The factory manifold had these carbs at a pretty good rake and end carbs are progressive - either mechanical or vacuum linkage starts opening throttles when center carb throttle opens something like 60%.
    It might be worth fabbing block-off plates for end carb bores - see if things straighten out with just center carb functioning. Good luck!☘️
  8. Mimilan
    Mimilan
    This was needed to correct the angle of the engine in the engine bay
    When installed the carbs were level.
    @James Halsey
    A car can easily drive on a 7° gradient, so it isn't a major cause/ issue
    Also are your small 2G's rebuilt?
    An often overlooked problem on 2G's is the check-ball for the accelerator pumps [they leak bad and cause it to run too rich]
    The ball needs to be seated by using a small br*** punch [use a piece of brazing wire]
    You give the ball a gentle "twack" with a screwdriver handle onto the br*** punch.
    The stainless steel round ball seats against the "shoulders" of the hole.
    It is under the boosters [you pull out the T retainer that locates the spring]
    jet996, 1929rats, swade41 and 2 others like this.
  9. Mr48chev
    I worked in Pontiac dealerships as a front end mechanic in the 70's and the engines always sit in Pontiacs at that angle at least from early 60's on for transmisison clearance. That is the reason that the manfold has the carb mount surfaces at that angle. Lower the back of the engine to where the intake manifold carb mount surfaces are level and problem solved except for totally wrong carbs. Who ever installed that engine in that car installed it wrong for what it is and set the car up like a flathead or some earlier V8's with the intake on the same plane as the valve covers call for sitting level.Early nailhead Buicks come to mind there. I'm rather thinking that with GM you see a difference between up through 57 intakes and 58 or maybe 60 and later on most V8 engines.
    jimmy six and Ratmother like this.
  10. James Halsey
    James Halsey
    Thanks for all the replies, answers below to questions asked:
    Oneball: that IS outside the box, cutting off the water crossover is a pretty common modification for racers that remove the intake frequently, the KRE Tradewinds manifold is sold with no water crossover. What is less obvious is whether the manifold ports are absolutely symmetrical. I have an extra manifold, I will take photos of the ports and study them.
    Carbking: Option 5: three large base Rochesters, if I could find them, they are hideously expensive ($5k) and would they be any better than the small base 2G’s operating at -7.5 degrees ? I don’t see why, the float bowl design is the same, yes?
    The carbs came from Vintage Speed, completely reconditioned and designed for tripower use. The center carb has idle circuits and a power valve while the end carbs do not. I have the end carbs blocked off now for trouble shooting purposes. Idle byp*** in center carb, yes. Spring changed was in the power valve actuating rod, not the power valve itself.
    The engine was run on the dyno ( I presume level carbs) and made 367 HP at 5000 rpm and 433 ft lbs of torque at 3900 rpm.
    Joeblow: yes, Keith Cornell built this car
    Ratmother: I do have the end carbs blocked off at the moment and I am using the Vintage Speed mechanical progressive linkage.
    Mimilan: I did change the accelerator pump check valve but just dropped it in the hole without giving it a gentle “twack”. I will do this, thanks.
    Mr48chev: I understand what you are saying about the engine angle in the ch***is of original Pontiacs, I have a 65 GTO Tripower 4 psd that I have owned for 40 years and the carbs sit close to level. I can raise the engine and lower the trans maybe 1/4” without major issues, not sure that will be enough to cure my problem.
    I will pursue the idea Oneball had of turning the manifold around and also call KRE to ask about their Tradewinds manifold.
    Thanks again for all the help.
    Joe Blow and Oneball like this.
  11. James Halsey
    James Halsey
    Just spoke with KRE and they say their Tradewinds manifold has a cast in angle similar to OEM. But they say there is plenty of material there to mill it flat.
    They also said OEM manifold ports are symmetrical and it will fit turned around. So this is what I will attempt, cut the water crossover off with a bandsaw and reverse the manifold. That should give me a carb flange angle of +2.5 degrees. That could be reduced, if needed, by milling the manifold directly but I doubt it will be necessary.
    Thanks again Oneball and everyone who responded.
    Another issue I have been working on is the suspension has a loud banging noise over bumps. Sounds like its coming from the back. I have inspected the suspension thoroughly and see nothing obvious. The car employs torsion bar springs so its somewhat unusual. It uses heim joints with no rubber anywhere.
    When I get the engine sorted, I will post pictures of the suspension and see if anyone has ideas as to the cause of the noise.
  12. Oneball
    Oneball
    I guess with my daft idea the critical bit is going to be leaving enough of the flange to close this off. And distributor clearance 20251118_165141.jpg
  13. Joe H
    Joe H
    It seems to me an easier option is to weld the manifold bolt holes shut and re-drill to fit your current carburetors, then try to match the ports best you can. A good aluminum welder could also close up part of the ports so you would have room to open back up to match the bases.
    Turning the manifold around sounds like a bad idea and sealing nightmare.
  14. Does look like the engine itself is sitting odd
  15. hepme
    hepme
    Had the large base on an edlebrock on a 355 chevy. Flow rates on those are a bunch-like 350cfm for the smallest one if I remember correct. I'm cheap so I'd shop the meets and find dogs that I could overhaul. Got a few for like 5 bucks. Use progressive linkage, run off the center only (here its nice if you can find a stock one and just rebuild it). Level angle on the center is what I used, ends were for dumps only-didn't matter. Original tri power probably had set angles, etc. but running off just the center one sure seems to work.
  16. alchemy
    alchemy
    Vintage Speed huh? Did you ever suspect the carbs themselves were the problem?
    mkubacak, swade41, oj and 1 other person like this.
  17. pprather
    pprather
    Why not start with this?
    Then see where you are at before cutting up a perfectly good intake manifold.
    Step 2, as @hepme suggested, search out a large base carb to use in the center.
    If rod still runs badly, some additional research and troubleshooting may be required.
    GuyW likes this.
  18. carbking
    carbking
    I don't know what carbs you have, but they do have Chevrolet throttle arms, so.....
    In the "for what its worth" category:
    Small base 283 Chevrolet Rochester was 1 3/32 inch venturi (area 1.88 square inches)
    1965 Pontiac 3x2 center small base Rochester was 1 1/4 inch venturi (area 2.45 square inches)
    The 389 Pontiac center is a bit more than 30 percent larger than the 283 Chevrolet carb.
    Jon
  19. oj
    oj
    Nice car, looks like it would cruise effortlessly, tough to achieve that kind of look.
    If the 'top gasket' you speak of is indeed the top gasket under the cover, then the needle & seat are not shutting the fuel off, it could be the float itself or poor quality needle & seats It should be an easy fix.
    jet996 likes this.
  20. James Halsey
    James Halsey
    well, the idea of cutting off the water bridge and reversing the manifold didn't work, didn't clear the distributor. It was worth a shot.
    Now I am thinking of purchasing the Tradewinds TriPower manifold from Kaufman Racing Equipment. Stock port sizes and probably Holley2300 bolt pattern. I'm hoping the Holley carbs will deal better with the mounting angle with their center hung floats but also this manifold is a two piece design with the basic single plane manifold and a top plate with plenty of material that can be machined if I need to deal with the flange angle.
    If anyone is looking for a set of small base Rochestersset up for TriPower application, I may have a set, we'll see.
    Oneball likes this.
  21. Joe H
    Joe H
    I don't understand how the angle can effect the mixture, the jets and power valve are towards the throttle bores while the float and needle valve are towards the front of the carburetors. Angled forward should make them lean with most of the fuel towards the front. During acceleration, they should be perfect since all the fuel will head towards the jets.
    I'm betting all the poor running is due to the cam ( low vacuum ) and undersized carburetor. Every Tri-Power before 1966 had the small center carburetor. Find a standard 389 or 400 two barrel and bolt on with the two outers blocked off, bet it runs much better.
  22. 19Eddy30
    19Eddy30
    from VA
    Olds or Buick late 60's early70's had a large base & one
    Of the modle's & engine combo if I remember correct was over 500 cfm like
    560 or 570 cfm 2 barrel.
    I made my own adaptor , ran way better
    Then 3 carbs Et & Performance.
    Sbc thoe.
    Then later switched to 2 Holley 2b's
    On Vic ram ,
    Me If not a roots blower , odd carbs intake Not like 2 carbs 4 carbs or 6 &8
    The even is better choice ,
    A single or 4 & 8 Non tunnel ram ,
    2 carbs Holley Strip & Vic Ram are the best That are not sheet metal , On sheet metal Split carb work well.
