Changed brake pads and now it pulls
Discussion in 'The Hokey Ass Message Board' started by deto, Sep 9, 2012.
  1. deto
    deto
    I have a Camaro clip on my 52 with discs. I just put in new pads and noticed that the driver side piston was noticeably hard to press back into the caliper. Now when I panic stop it pulls towards the passenger side before I get both fronts to lock up. Do I have a bad caliper?
  2. Heo2
    Heo2
    yes
    You can put back the old worn pad
    and exercise the calipper
    Press back the piston and all the way
    then press the brake pedal till
    its all the way oute and press it back
    again till it moves frealy
  3. deto
    deto
    What about brake hoses?
  4. Heo2
    Heo2
    Naaah dont think so ...guess its possible
    but i think its the calipper here where its
    cold and damp you have to exercise the
    calipers almost every time you change pads
  5. deto
    deto
    Why is that?
  6. deto
    deto
    Shit I threw away the old pads. Time to go dumpster diving
  7. Sphynx
    Sphynx
    from Central Fl
    I agree about the hoses. I had the same problem with a O/T chevy truck. However the old pad trick would be cheaper and worth a try.
  8. deto
    deto
    Ok will do
  9. Deuces
    Deuces
    I'd just replace both calipers... The driver's side one is probably froze..
    Rebuilt calipers for Camaros are cheap.. 14.99 per side.. I'd spend the money..;)
  10. deto
    deto
    Ha! I already reserved them at napa... I'm lazy!
  11. Heo2
    Heo2
    Yes its the proper way to do it but...or was 20 years
    ago. Today a 14.99 caliper is probably rebuilt by a
    blind child labourer with bad parts so....
    The exercise way is the fast cheap lazy way not maby the best
    but it works as long as the caliper dont leak
  12. deto
    deto
    I'll take my chances
  13. willowbilly3
    willowbilly3
    from Sturgis
    Chevy calipers are cheap, just get new ones, both of them. How hard is that?
  14. GM calipers are easy to rebuild, but the kits might be as much as a rebuilt caliper. I just don't trust someone else to do my calipers. Buying new ones is one way to go if you haven't done many of them.
    If you ever want to blow out a caliper and don't have the pads around, use a scrap piece of wood, anything will do.
    Bob
  15. willowbilly3
    willowbilly3
    from Sturgis
    I don't generally have much use for over the counter reman parts but I've installed hundreds of calipers and never had one defective. I usually buy the loaded ones. I got the ones on my rpu from a dirt track supply store, around $35 per IIRC, new ones too, not reman. The kit and the piston would cost that much.
  16. I would highly recommend changing brake hoses. They get very hot and take a "set" and when disturbed, as in changing pads, they often break inside and cause problems. But then, how much is your car worth and how much is your life worth? A few bucks spent in the right place is a worth while.
  17. pastlane
    pastlane
    More than likely the caliper, but don't be too quick to dismiss the brake hoses either. They do go bad internally.
    I had that problem with an OT truck. In a panic stop it would pull hard to the left. Eventually the RH caliper locked up tight. The RH hose looked like new on the outside but cutting it apart revealed the inside was like a bad artery, totally clogged from the hose breaking down.
  18. deto
    deto
    Shit... Looks like I'm gonna buy hoses now too
  19. if the calipers are just grabbing and they are releasing the hoses are usually ok but replacing them is a good move then you know what you have if a different issue comes up.
  20. On GM cars, the pistons rarely go bad. Fords and Chryslers didn't have as good a dust shield on theirs and I saw many with pitted pistons with the chrome finish destroyed. GM caliper pistons had a different finish them too.
    I believe that the last caliper kit I bought for a GM car was $18 and this was maybe 8 years ago. I've bought lots of remanufactured calipers for customers cars over the years and only saw some bad ones where the dust boot was installed improperly. I took an extra 3 minutes, blew it out and reassembled it the right way.
    Bob
  21. deto
    deto
    so check this out. The car sat for 2 days and when I got in it this morning it stopped straight on multiple attempts. After about 10 minutes of driving I hit the brakes again and noticed it pulled again, but not as bad. Does this change my situation?
  22. Something is sticky... if it was my car, I'd be adressing the calipers and hoses. Gotta disconnect the hoses to deal with the calipers anyway, may as well put new ones on.
    Bob
  23. deto
    deto
    word. I'm headed to napa now
  24. worken2much
    worken2much
    I've run across this twice in the last year when replacing brake pads. The pads hang up on the rotor & don't retract. So one side may have the pad dragging on the rotor while the other has to travel. Check the notches on the pads where they ride in the caliper. I've had to clearance a couple sets with a dremel & die grinder to get them to work properly. Dragging pad shelled out one rotor in about a year.
    Good luck,
    Worken2much
