Changing bolt pattern on rear end?
Discussion in 'The Hokey Ass Message Board' started by noblebeidoun, Apr 15, 2013.
  1. noblebeidoun
    noblebeidoun
    from Michigan
    First off, I'd like to thank everyone for guiding me through my noob questions haha. Anyways, i just picked up a maverick rear end for my ford Model A. My question is simple, the bolt pattern on the maverick rear end 8 inch doesn't match up to the model a tires. The model a is a 5.5 pattern, and I believe the maverick is 4.5. How can I resolve this issue?
  2. you will need wheel adapters....check with wheel kid
    even if you could re-drill the maverick rear to 5-1/2......and you cant because the axle flange isn't big enough..... the drums will never fit inside those wheels
    scroll down to the bottom of this page
    http://www.rallyamerica.com/Adapters.html
  3. 226 flattie
    226 flattie
    from orange,ca
    You can find ford axle shafts with 5 on 5 1/2 bolt pattern with the same spline count. And length . A axle shop can modify axle shafts .
  4. noblebeidoun
    noblebeidoun
    from Michigan
    i was looking into the adapters, but would that add too much to the width of the rear end? those adapters look at least half an inch wide meaning it would increase the length of the rear end by at least an inch, also, our MOdel A project is a full fender car
    And we considered also having the shafts changed, however, we want something cheap and easy.
  5. You could use narrow tires. But if that does not appeal, you could slice the rear fenders front to back and then add in an inch in the center.
  6. noblebeidoun
    noblebeidoun
    from Michigan
    well we were gonna use the original Model A width on the tires, would it work then?
  7. oldcarguygazok
    oldcarguygazok
    from AUSTRALIA.
    Maybe the wheel centres can be cut out of the Maveric rims and welded into the original rims?
  8. let me get this straight ....are you using the original Model A ford wheels? that's the way i read your original post
  9. dreracecar
    dreracecar
    from so-cal
    New axles (Moser, Superior,K-A) are safe and inexspensive, they can make them any way you want.
  10. Mr48chev
    Yep Moser http://www.moserengineering.com/axles.html Or Dutchmans http://www.dutchmanaxles.com/
    and probably a few others can make you a pair of correct axles for not much more than what a pair of quality adapters would cost.
    I just checked the price of good quality adapters after reading a thread on a truck board and starting price was 89 each and the minimum thickness was 1.9 inches. US made and not knocked out with a cookie cutter. Prices went up from there depending on what you needed.
  11. 31Apickup
    31Apickup
    You can look into early Ford Bronco axle shafts, (66-77), they came in 28 & 31 spline, both small & large bearing. You would need the small bearing 28 spline. I don't know if the stock lengths are usable, last I seen they were around $115 each.
  12. young'n'poor
    young'n'poor
    from Anoka. MN
    Get some axles made is the easiest solution. But like somebody else asked, were you gonna run the A wheels? I can't imagine the maverick drums will fit behind those...
  13. noblebeidoun
    noblebeidoun
    from Michigan
    we did plan on using the Model A wheels, didn't even think to wonder whether or not they would fit on drums. Now we face another problem haha.
  14. tb33anda3rd
    tb33anda3rd
    i don't know if you can find them but the shea model A had four lug wheels.
  15. the wheel adapters i showed you will fix both problems
  16. noblebeidoun
    noblebeidoun
    from Michigan
    36-3 Window, would they still fit into the fenders with no problem using those?
  17. Andy
    Andy
    The early Ford wheels have a lip that overhangs the mounting surface. You must use wheel adapters for this lip to fit. You also need support for the inside of the wheel mounting surface. Spacer rings or get an adapter with them built in. A Maverick with adapters will be the same width as a stock A rear.
  18. noblebeidoun
    noblebeidoun
    from Michigan
    Okay then perhaps I should just go with adapters
  19. Atwater Mike
    Atwater Mike
    Go with adapters. Google Rally America (Wheelkid) and order a pair of his Kelsey-Hayes adapters. Listed at $75 each.
    They are 1.25" thick, and allow you to bolt Model A thru '35 Ford V8 wire wheels right on.
    And your tread width will be about the same as Model A.
  20. Mr48chev
    That would probably be a good fix. Scroll down the page.
    http://www.rallyamerica.com/Adapters.html Those have the raised lip for the wire wheel to sit correctly on.
