Anyone know how to drop the lower control arm on the 50 Plymouth. I want to change out the coil springs. Would you disassemble the front Spindle section in the front or pull the pin out in the rear of the lower control arm. I put the question up on the PD guys but haven't got a clear answer, Thanks for any input, Stan
Pull the king pin bolt at the spindle. If you pull the bolts at the arm you will have to align it again. Posted using the Full Custom H.A.M.B. App!
