My -52 customline needs a new pinion seal.Now,I have the seal but the Shop Manual says theres supposed to be a gasket under the oil slinger.Mine dosen't seem to have one.What kind of a gasket should there be?Between the bearing and oil slinger? Also,is there a proper way to put yoke back in without using the special tool the manual tells me to use. ?
Check this out: https://www.hotrodreverend.com/single-post/2017/10/02/55-Ford-Fairlane-Restoration-Blog-Part-23 I do not remember a gasket like you describe, but maybe you have a rear end that is a little bit different?
