Changing Rear End Gear Ratio
Discussion in 'The Antiquated' started by Tracy Horsley, Jan 28, 2023.
  1. Tracy Horsley
    Tracy Horsley
    Folks, need suggestions for changing the rear end gear ratio on a 1952 Chevy 3100 truck. I'd like to be able to drive it at higher speeds. Are there kits out there to do an upgrade? Thanks.
  2. jimmy six
    jimmy six
    Not much was ever available. A guy in AZ. was making higher gears, I believe 3.55’s but he had many many problems and stiffed a few folks. I knew him but never ever did business with him. He has p***ed on.
    Your better off getting a 54 2nd series transmission thru 59 that has an open drive line (guys are up grading so it should be too hard to find one and your stock column linkage in a bolt up) and changing the complete rear end. An 8.8 is reliable and they are in every bone yard. I believe the flanges are big enough to redrilled for your 6 bolt pattern.
    Deuces likes this.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I would swap in an 8.8 or a NineInch. Lots of ratios are available for either. With a little sleuthing you can probably even find one where the spring pads align. I think my buddy did a Bronco 8.8 in his '58 Chevy commercial van that was the correct width.
    Deuces likes this.
  4. jnaki
    jnaki
    https://www.cl***ychevusa.com/
    Hello,
    For most Chevy truck parts and set up information for older ones, these guys have a ton of resources. Go to the website and/or call them. They are very nice about information and things related to old Chevy trucks.
    Jnaki
    They are located in So Cal. And, have a lot of cool trucks/information under their belts.
  5. Blue 52
    Blue 52
    If it might be helpful, I used a 70s 10 bolt? Rear axel on my 52 and then swapped in axle shafts from a 79 4x4 as they have the right 6 bolt pattern
