Changing stuck tie rods
Discussion in 'The Hokey Ass Message Board' started by Hellfish, Aug 25, 2008.
  1. Hellfish
    Hellfish
    I'm trying to change the tie rod ends on my Econoline, but they won't budge. I removed the rod from the van and put in a vice, but no luck. It's been doused with Kroil penetrating oil, too. The clamp is loose. Any other tricks? All I have is a Bernzomatic propane torch for heating.
  2. 41hemi
    41hemi
    I think if you use a little heat on the tube you will have success. I usually never-seiize the threads on the new tie rods when they go back together. Al
  3. hotroddon
    hotroddon
    The propane torch should help. When i have had that problem I used WD-40 and a torch. The heat would wick the WD into the threads and loosen the rust. Be careful though, it is flammable, don't spray it near the flame
  4. Hellfish
    Hellfish
    heat the tube, not the tie rod end, right?
  5. hotroddon
    hotroddon
    Yes
  6. Hackerbilt
    Hackerbilt
    Heat is good...
    Also you can hold the tierod tube/tierod on the anvil part of your bench vise and hit it with a hammer while rotating the tube with your hand. Pinch the tube/tierod area between the hammer hits and the anvil kinda thing. Have the clamp back outta the way.
    Frees up the rust thats bonded to the threads and lets the penetrant soak in much better...
  7. Goztrider
    Goztrider
    from Tulsa, OK
    What about using the pickle fork attachement for an air chisel? I've seen them work their way into and loosen some of the nastiest stuck tie rod ends.
  8. johnrockin
    johnrockin
    from midwest
    put the end in the vice, heat the rod up with the torch(but an oxy acet would work better) and put a big *** pipe wrench on the rod.
  9. One car when the ends went bad I swapped the whole tie rod off a parts car into it. Luckily that car had been aligned pretty decent.
    Seems to me most of them are split and if you could spread them a little it should break the rust, but I don't know what an Econoline tie rod looks like.
  10. Hackerbilt
    Hackerbilt
    True...but he must have them out of the tapered holes already...he has it in the vise!
    Geezzz...I suppose he doesn't have spindles and all up on the bench!?!? Hahaha
    Now THAT would be funny! :D:D
  11. SlowandLow63
    SlowandLow63
    from Central NJ
    You can't find sleeves as well as the new tie rods? That would simplify the problem much more.
  12. Hackerbilt
    Hackerbilt
    His Econoline has a straight axle...so it has a one piece tie rod tube like an early Ford car.
  13. SlowandLow63
    SlowandLow63
    from Central NJ
    So they sell the ends but not the tube? Thats a bit ridiculous.
  14. Hackerbilt
    Hackerbilt
    Hmmmm...Someone must sell them I suppose...but it goes from one wheel to the other if I remember correctly.
    But...if the tube is still straight and solid with no deep pitting etc, I'd just get the old tierods out too!
    Who knows...getting a specific tube of that length might involve a 2 week wait or something and might cost an arm and a leg. Pre 69 Econoline ch***is parts don't exactly fill the aisles at PEPBOYS anymore!!!:D
    Personally I've NEVER had to work too hard to get them loose anyway.
    It's all in how you go about it!
  15. SlowandLow63
    SlowandLow63
    from Central NJ
    Absolutely. Not trying to play the voice of reason here, just more shocked than anything. You would think that a company would make the entire ***y, not pick and choose. But then again like you said, they don't exactly stock them at Pep Boys.
    Back to the question at hand. Heat, lube, and make sure you are turning it the right way. One should be left hand thread and the other right, no? Unless I'm completely clueless as to an Econoline front end.
  16. Hellfish
    Hellfish
    You're right, Slow, but I don't know which is which. If I could turn them either way it would be progress.
    The funny thing about Econolines is that they were ignored from the 70s until now, so very few parts are made for them unless they were shared with other trucks/Broncos. Econolines consist of a lot of Econoline-only parts. I'm lucky that MOOG had the tie rod ends. The tube is almost as wide as the van, so replacing it, so I would imagine a new one would be pricey and shipping a new one would be pricey, too... if I could find one that wasn't stuck.
    Hacker, the rod is on the bench, not the whole axle!
    Rusty, I may try prying the tube apart at the split, but won't that risk damaging the tub and rendering it useless?
    It has a lot of gunk caked into the split in the tube (the engine leaked a LOT). I heated the tube up pretty good with propane last night and soaked it with Kroil. Hopefully it will be a little loose today. If not, I may have to borrow a Oxy torch
  17. beernut
    beernut
    from solvang
    there is a tool that hooks the split in the tube and opens it as you rotate it ,it looks like a -c- with a handle on it.not very expensive from mac,snapon ect,and use lube.i have worked as a alignment tech for 25 years and this is the best way to adjust the tierods,with the ***mbly out of the car just put the rod end (with nut on it)in a vice to hold it,a pipe wrench is my last resort,and not on the part thats over the t.r.end thats threaded as it clamps down on it and makes it tighter
  18. Hackerbilt
    Hackerbilt
    I know that! :D
    Give it a good wire brushing to see the direction of the threads. Then you'll know which way the rod end turns.
    I wasn't kidding...give the threaded part of the tube, with the tierod still in it but the lock clamp loose and pushed back out of the way, a few good hammer smacks against something solid like the anvil of your vise.
    Like your trying to flatten the tube/tierod threads against the anvil. Roll it around and hit it all over.
    You don't need to beat the **** out of it...but it seems to loosen the rust and actually stretch the tube metal ever so slightly...enough to get some movement and allow the oil, or heat for that matter...to work much better.
    As for heat...unless you have a powerful source of heat you will expand the tierod at about the same rate as the tube so it doesn't do as well as you would think.
    Oxy/act is the very best thing to use.
    You'll get them off. :)
  19. CTaulbert
    CTaulbert
    from Detroit
    Soak the ends in some Coca Cola overnight - I wouldn't be surprised if it comes out pretty easy. Its worked for me!
  20. studedudeus
    studedudeus
    If you want to replace the whole thing, go to Speedway Motors. They have tie rod kits for anything from street rod to sprint car. I use them on my Studebaker. You can choose either rod ends or heim joints, and either clamp on or jam nut style. You just pick the length, they do the rest.
    One happy customer here.
  21. spinout
    spinout
    from Dallas, TX
    What Hackerbill says....about 3 posts up.....
  22. lodaddyo
    lodaddyo
    that propane torch is probably not gonna get the tube hot enough to expand and loosen its grip on the tie rod ends. if you can get access to a oxy/actylene rig it would be better. also ditto on what stude says, speedway motors would be the place to go to for the new tube and tie rods.. also see if you can find some **** called "breakfree", gunsmiths use it. and it works!, kroil cant hold a candle to it
  23. 55 dude
    55 dude
    get some mapp gas at home depot and a beeswax candle,never had anything beat that combo.
  24. Hellfish
    Hellfish
    I've got MAPP... how about bees wax hair pomade? I have that. Now wouldn't that be the ultimate rockabilly car fix?! :D
  25. fab32
    fab32
    The absolute best way to break the rust bond. If needed repeat a couple of times with penetrant used between the hammer sessions.
    Frank
  26. Hellfish
    Hellfish
    I'll give all these methods a try, and if that doesn't work, I'll try Speedway. Those aren't as expensive as I thought... if they have them in the right length.
  27. Bruce Lancaster
    Bruce Lancaster
    You mention crud...clean the area as well as possible on wire wheel. With typical layer of grease and dirt, your penetrant isn't going anywhere that it is needed.
    If actual tube is split, drive a small chisel into split...figgerout a way to tap it along split form end towards middle, perhaps custom grinding chisel to a lateral taper for this.
    The split opener tool mentioned is for the clamp, not actual tube.
    Get local parts counter guy to check Moog catalog or equivalent before ordering Speedway tube...I think their stuff is for early Ford/later pickup ends, and I know that lots of Econoline bits are smaller than regular pickups.
  28. Goztrider
    Goztrider
    from Tulsa, OK
    Depending upon the size of the tie rod threads I've got an easy way to make your own tie rods. I made the cross steer tie rod on my RPU for $15 not counting the tie rod ends.
