Technical Changing valve seals SBC
Discussion in 'The Hokey Ass Message Board' started by Ralphies54, Dec 18, 2015.
  1. Ralphies54
    Ralphies54
    Tried the search function but no luck. What is the tool called that inflates cyl. and what does it look like? I'd like to at least sound like I know what I'm talking about when I go to buy one. Thanks Ralphie
  2. http://www.summitracing.com/parts/l...Sap3dhhc5HVeR4-7vrhJ6VE3D3Io2BpZ8khoCWkHw_wcB
    http://www.amazon.com/Lisle-19700-V...466884&sr=8-1&keywords=spark+plug+air+adapter
    • Commonly used when valve springs or valve stem seals are replaced
    • Comes with two-step fitting for both 14 millimeter and 18 millimeter threads
    • Thread fitting to spark plug hole and other end to air supply
    • Heavy duty 12" flexible hose allows easy access to spark plug hole and air supply
    • Air pressure helps prevent the valve from falling into the combustion chamber
  3. oldolds
    oldolds
    Wow! how fancy. Mine is an old spark plug. hollowed out with a piece of pipe brazed on and some old air hose with a quick coupler clamped on.
    lothiandon1940 likes this.
  4. bonzo-1
    bonzo-1
    My compression tester has the same quick disconnect as the shop air hose.
    I prefer to shove a bunch of rope in the cylinder and rotate the piston up.
    It is easy to bump the valve too hard break the seal and have it drop with just air pressure.
    wedjim likes this.
  5. hotrod1948
    hotrod1948
    from Milton, WI
    You can also use a length of nylon rope, Feed it into the spark plug hole then hand rotate the engine to squeeze the rope into the valve faces. Works better than air if the valves bleed a bit or if the keepers need a bit of persuasion.
  6. hotrod1948
    hotrod1948
    from Milton, WI
    Bonzo types faster than me!!!^^^^^
  7. 4wd1936
    4wd1936
    from NY
    If you are in a bind or don't trust the air you can accomplish the task with a piece of nylon rope through the spark plug hole twirled as it goes in, then bring the piston up to hold the valves. Takes a little practice but it works. Note: Don't forget a handle on the rope so s... doesn't happen.
  8. 4wd1936
    4wd1936
    from NY
    Great minds think alike, sorry about that one.
  9. oj
    oj
    Spend some time to flush your air compressor and get a filter for it, air compressors are full of trash, water and nasty **** you don't want in your engine.
    timwhit and lothiandon1940 like this.
  10. Ralphies54
    Ralphies54
    Thanks for the replies.
  11. 4thhorseman
    4thhorseman
    from SW Desert
    In my youth I have changed them out, a pair at a time, by removing the rockers and just feeding in a length of white, soft, nylon rope through the spark plug hole - leaving some hanging out - and bringing that cylinder up to TDC or until it squishes the rope filling the chamber and stops the piston. A $15 dollar valve spring compressor bar that uses a little leverage and out come the keepers. Valves cannot fall anywhere. Voila. Re***emble and move onto next pair. Just sayin' more than 1 way to skin it.
  12. I hope that will work on a olds 350 motor also? Bruce.
  13. Hoptup32
    Hoptup32
    I've used the spark plug air adapter on my SBC several times, it works great. You need to use about 100 psi to keep the valves in place while you change out the seals. Another tip, use a little dab of grease on the valve keepers when you reinstall them, it helps keep them in place while you release the valve spring compressor. FYI, when you are hunched over concentrating on trying to reinstall the valve keepers, the air compressor will kick on and scare the sh*t out of you!
    mad mikey and Montana1 like this.
  14. I use the rope method. It works and there isnt any danger of dropping a valve. If for any reason you lose the compressed air you could drop a valve and end up having to pull the head.
  15. Rocky
    Rocky
    Classified Editor
    I've used both the rope and the air method. I once agreed to swap out a broken valve spring in my body man's chevy if he'd put some flames on my primered 56 Pontiac. I used a hunk of his mom's clothes line to do that one.
    Here's a very important hint: If you use compressed air, Always make sure the air is run through a drier before it's goes into your engine. I didn't and had to tear my engine down to repair rusty valves and seats after pumping moist air into it to swap out some valve springs. Engine sat a few months after doing the work and rusted.
  16. ClayMart
    ClayMart
    There's the important part. DON'T use the starter to bring the piston to TDC. :oops:
    Also, if you're using the air pressure method, it's not a bad idea to loosen the radiator cap before pressurizing the cylinder. If the engine has a leaky head gasket or a crack in the right place you can end up pressurizing the cooling system. And it's not designed to handle that kind of pressure. Blowing a heater or radiator hose will make quite a mess. And if you're working on a hot engine the scalding coolant can cause a less than pleasant experience. :eek:
  17. Jalopy Joker
    Jalopy Joker
  18. mad mikey
    mad mikey
  19. Ralphies54
    Ralphies54
    I believe I will use the rope method, seems foolproof and my air supply is anything but dry and truck will be setting for awhile so as Rocky suggested I don't need the rust possibility. Thanks again Ralphie
