Hot Rods Channeled Model A Rear End Width
Discussion in 'The Hokey Ass Message Board' started by krylon32, Nov 6, 2021.
  1. krylon32
    krylon32
    from Nebraska
    I need a little help. I'm going to do a ch***is for a channeled 29 A sedan. I'm in a quandary about the outside width of the rear end. I don't want it to wide but also not letting the tires rub the body. I've contacted a notable builder of channeled A's and he says 62-65 inches. Car will be running tall skinneys. Thanks
  2. Ratspit
    Ratspit
    What brake setup are you using on the rear axle? With tall skinnies sometimes it's more about where the backing plates end up.
  3. sawbuck
    sawbuck
    from 06492 ct
    that sounds wide ....58 to 60 inch
  4. krylon32
    krylon32
    from Nebraska
    Using the standard 11 inch Ford drum brake. My normal rear end width for a non channeled A is 56 inches.
  5. Ratspit
    Ratspit
    Do you know what the width of the rims are going to be? Offset? I agree with Sawbuck 62-65" seems really wide.
  6. krylon32
    krylon32
    from Nebraska
    I contacted another builder today that has done a few channeled A's and he recommended a 60 inch outside width with 16X5 inch rims with a 3 inch back set.
  7. don colaps
    don colaps
    But those can not have been sedan bodied?
