Hot Rods Charging system problems.
Discussion in 'The Hokey Ass Message Board' started by Boden, Oct 25, 2020.
  1. Boden
    Boden
    I installed a power gen on my 53 with a merc flathead. It installed great and charges amazing! But now when I give the motor some rpm it makes a grinding/squeaking noise. Almost as if the starters trying to engage. So at first I figured it was the solenoid since it was the original 6v and the car is converted to 12. I bought a solenoid for a 56 ford. And it still does it! Any ideas on what it can be?
  2. 4ty
    4ty
    Disconnect the fan belt(s) and see what happens.
    Paul in CT
    Boden and Truck64 like this.
  3. Elcohaulic
    Elcohaulic
    Make a video of it acting up and post it..
    kidcampbell71 likes this.
  4. Boden
    Boden
    I disconnected the wire off the alt and the problem goes away. Do ik it has something to do with the actual charging wiring
  5. 325w
    325w
    Some how it's feeding back and making the solenoid try to engage. Look at instructions and see if it says anything about adding a diode to stop feed back. Maybe give then a call Monday?
    Boden likes this.
  6. Boden
    Boden
    I had someone else suggest the diode aswell. But I will give them a call Monday. Thanks for the response!
  7. jaracer
    jaracer
    Yes, it sounds like a diode/stator problem since it goes away when you disconnected the wire. If you know anyone with a scope you could check the output pattern.
  8. Boden
    Boden
    Figured it out for anyone who cares..... changed the coil and the problem went away and it charged fine.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    Coil ? Ignition coil ?
    Boden likes this.
  10. Boden
    Boden
