Technical Chasing Parasitic Draw Help
Discussion in 'The Hokey Ass Message Board' started by bustingear, Oct 11, 2023.
  1. bustingear
    bustingear
    Trying to get a test done on my one wire alternator and having a time of it. Took it into Autozone and Advance and they need a number for a one wire to put into their testing machine and cant seem to come up with one that is currently in there. It is for a small block chevy #7127 but converted to one wire. Can anyone come up with a fitting number in their machines? Long story but its out of the car and i cant take the car in. It is a project at the end of the build and not running yet. I need to trouble shoot some bugs and need to eliminate the alt form the mix. Thanks in advance
  2. Mike VV
    Mike VV
    from SoCal
    It's a..."one" wire...device !
    Put it back in the car, make sure that it's grounded "properly", connect ONE (10 gauge min.) wire to the "battery" post and the other end to the positive post on the battery.
    Make sure that the car has a volt meter / gauge in the car, or buy one, and connect it to the electrical system (!).
    Start the engine, watch the gauge needle.
    If the gauge doesn't read anything, the alternator is bad. If it reads low (below about 12 volts) voltage, rev. the engine a little and see what happens. If it's still low, then the alternator is bad.
    The gauge should read a high 12 to mid 13 volts to be a good alternator.
    Simple, a five minute job.
    That's ALL there is to it !
    Mike
  3. squirrel
    The alternator won't work until you get it spinning....and then you can put a volt meter on the wire and see if it's working.
    Since it wasn't used on any production cars, it's not likely that you'll find a setting on a tester for it, eh?
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Does your town have a Alternator Starter or Auto Electrical repair shop that doesn’t have key board staff?
  5. Take it to O’Reilly and have them test it as a Wilson 90-01-3125
    alanp561, Bob Lowry, ffr1222k and 2 others like this.
  6. squirrel
    or Autozone as a Proform 66434
    alanp561, Bob Lowry and ffr1222k like this.
  7. bustingear
    bustingear
    Thanks but I think you missed the part about not running yet....Takes alot of juice to get one started for the first time
  8. bustingear
    bustingear
    ok the two numbers led me to other cross over numbers , we will see what happens.
  9. Dave G in Gansevoort
    from Upstate NY
    This probably won't be any help. Back in the 80s when I lived in Columbus and worked at Battelle, there was a shop that worked on starters and alternators and the like on King Avenue about halfway between the thruway and Battelle. Probably gone by now, but if it's still there it may help...
  10. Dave G in Gansevoort
    from Upstate NY
    Wasn't on King Avenue. Other side of Battelle is 5th Avenue. Hey it's been a while...
  11. Mr48chev
    An alternator has NOTHING to do with an engine's ability to start except for having charged the battery to capacity before it was shut off last time. You do not need an alternator, generator or any charging device on an engine or even belts for that matter to fire it up for a few seconds. Meaning it "won't start because of the alternator" is total ******** if the battery has a full charge. You need the alternator to recharge the battery after you start and or run the engine long enough to put a drain on the battery.
    What you do need is a good strong battery and good cables to crank the engine to start it.
  12. bustingear
    bustingear
    So now that we are on it....I am chasing a draw. Can a bad alt show as a parasitic draw on a battery during a test with a multimeter between the neg cable and neg post even if the car has never been started?
  13. wheeltramp brian
    wheeltramp brian
    An alternator can have a draw inside. Have had a couple of these problems over the years even with a new one out of the box.
    Bandit Billy and Johnny Gee like this.
  14. bustingear
    bustingear
    understood but my question is can it show during a draw test even though car has never been started?
  15. dirt car
    dirt car
    from nebraska
    In some cases, even a burned-out idiot light will render a G.M. alternator inoperative.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If you suspect the alternator is drawing power do this. Have it connected as should be for a few hours. After which time but a multi meter to the battery and record voltage. Now disconnect alternators “1 wire” then watch multimeter to see if voltage creeps every so slow up. If it does, well…
  17. squirrel
    you can use an ammeter (or milliammeter) to find a current draw. But you might need to learn about what an ammeter does, and how to use it, so you don't create mayhem. Most digital multimeter have this function.
    hint: the ammeter goes in between the alternator and the wire that connects it to the battery. You do NOT connect one side to ground! Start with the meter on the highest current setting, and work your way down until you get an indication. If you get down to the lowest setting, and no current indication, then there is no draw.
    A leaking diode in the alternator can cause a draw.
  18. jaracer
    jaracer
    That test means that there is some live circuit, but it doesn't tell you where or how much current you are drawing. If you have a modern radio with a memory it will show as a draw with this test. However, the draw is so slight, maybe 10 or 20 milliamps, that it would take multiple months to draw a battery down. If you have a fuse block that allows you to get to all the fuses, a better test is to check the voltage drop across each fuse. That will allow you to pinpoint the source of the draw. Set your voltmeter to millivolts, mV, and connect the meter across the fuse, red lead on one side, black lead on the other. With everything turned off in the car, you should read zero across each fuse. Fuses that give a voltmeter reading means there is current flowing in that circuit. Fuse Chart.jpg
    Here is a chart that gives you current draw based on voltage drop. Note that the voltmeter reading is in millivolts (0.001 volt). Any reading that results in a draw over 150 - 200 milliamps will cause a battery to drain. The higher the number, the quicker the drain. So if you have a 30 amp fuse and you read 1.1 millivolts across it, the current draw on that fuse is 564 milliamps. That will drain a battery in a fairly short time.
  19. bustingear
    bustingear
    I am using the multimeter to measure draw and it shows none. Test is breaking between the neg cable and neg terminal. 10A setting. Battery volts are good 12.8V and its new. Starter is new. Problem when i start it i get about two revolutions and its goes to clicking and dead. Lights work fine when turned on.
    Its a small block chevy in a model A truck. No radio. Only lights and three gauges. Nothing that would create a constant normal draw. Advice appreciated
  20. 1971BB427
    1971BB427
    from Oregon
    If you suspect a draw on the electrical system, and easy way to check is to disconnect the negative battery terminal and with everything turned off in the car touch the negative terminal lead to the battery. If you see a arc of any size something is trying to draw power and you need to find out where it's happening or it will kill the battery.
    52HardTop likes this.
  21. squirrel
    Sounds like a dead battery. How old is the battery? If it's more than a month old, tell us it's history...
    or just try another battery.
    gary macdonald and Johnny Gee like this.
  22. BJR
    BJR
    Sounds like a battery or cable problem. Disconnect all the cables from the battery to the frame and starter and clean them with sandpaper or emory cloth. Do this even if they look good. Make sure the grounds are clean, both cables and where they attach.
  23. bustingear
    bustingear
    new battery tests at 12.8 V
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Load test will tell more than a voltage reading will.
    gary macdonald and MCjim like this.
  25. Bandit Billy
    Bandit Billy
    Charge the battery, unwire or remove the alternator, see if you still have a draw. Like @Mr48chev said, it doesn't need to be there to start the engine. If the draw is gone...process of elimination.
  26. bustingear
    bustingear
    Unfortunately not battery had it tested twice at two different places
  27. bustingear
    bustingear
    Yep did that and still current situation of two revolutions and no draw showing on multimeter
  28. squirrel
    Ok....how about you tell us about the battery's history. And let us know when you try another battery, and it works just fine.
    firstinsteele likes this.
  29. Bandit Billy
    Bandit Billy
    Do you have another battery? Take one out the daily.
  30. Oneball
    Oneball
    Hold on a mo. You’re trying to start it with the multimeter in series with the negative cable.
    Your multimeter won’t be able to cope with that sort of current. What’s it rated at 5amps max ???
