Chassis Engineering Inc - shut down?
Discussion in 'The Hokey Ass Message Board' started by swingcatt, Jan 8, 2013.
  1. chickenridgerods
    chickenridgerods
    from DSM, IA
    Sid drops original Ford (or Chevy, etc) axles.
    Ch***is Engineering manufactures (or more correctly, contracts out the manufacture of) new forged, dropped axles.
  2. plymouthgoat
    plymouthgoat
    from Wisconsin
    I've still got my 1996 Catalog however I just ordered a new one!
  3. A Boner
    A Boner
    John Deere?
  4. Max Gearhead
    Max Gearhead
    from Wisconsin
    That's correct.
  5. alchemy
    alchemy
    Pretty sure that CE uses a supplier who also makes parts for John Deere. JD doesn't make axles for CE.
  6. StefanS
    StefanS
    from Maryland
    Tried searching and searching and...searching but I'm coming up with nothing. I called and talked to a tech guy there but he couldn't provide the info I need due to not knowing every single detail of every single car they deal with, which is understandable. The motor mounts on my '54 are side mounts and bolted directly to the frame. What im trying to do is leave the motor mounts alone and use the CE crossmember and mII kit. Will the crossmember fit with the motor mounts where they are?
    Heavy Flat Head likes this.
  7. Malcolm
    Malcolm
    from Nebraska
    You might be better off starting a new thread to ask that question... More people may see it that way, especially with a descriptive thread ***le.
  8. StefanS
    StefanS
    from Maryland
    Haha I've tried before but I honestly have no idea how to do it
  9. 54 Chevy
    54 Chevy
    I use to have the side mounts on my 54 chevy. I don't think that it will work with the mustang 2 crossmember. I think the mounts will be in the way of the crossmember. Ch***is engineering makes mounts that are designed for the mustang 2 crossmember. They sit on the crossmember top hat. I am putting in a Kimbridge crossmember which is close in design and it uses the same mounts that fit on the crossmember.
  10. StefanS
    StefanS
    from Maryland
    Alright I appreciate the response my friend
