Chassis Engineering Mustang 11 Suspension
Discussion in 'Off Topic Hot Rods & Customs' started by jumbogem29, Jul 23, 2024.
  1. jumbogem29
    jumbogem29
    from Alabama
    Any one use the bolt in Mustang ll set up for a 40 Ford if so would like to see pictures thanks
    VANDENPLAS likes this.
  2. jimmy six
    jimmy six
    Not discussed on the main HAMB. Instead of GENERAL DISCUSSION use MISC and open Off Topic Hot Rods &Customs
  3. jumbogem29
    jumbogem29
    from Alabama
    Any one use this system.NO then what set up are you using Heidts, Kugel, Tci, Fatmans , Scotts which works the best and easy install
  4. Illustrious Hector
    Illustrious Hector
    Likely to find plenty of pics on their website, We installed a CE unit on a '52 Chev sedan delivery where I used to work. Quality pieces , well built.
  5. rockable
    rockable
    I had one on my 54 Chevy, and it worked out great. Talk to George at Heidt's. They now own Ch***is Engineering.
  6. poco
    poco
    from oklahoma
    I installed one in a 39 ford and also one in a 48 chevy both were easy to install and worked very well.
  7. jumbogem29
    jumbogem29
    from Alabama
    Thank for the replys i like the bolt in from ch***is Eng for a 40 ford
  8. chevyfordman
    chevyfordman
    I like the bolt in myself, worked great on my 48 Chevy; with the CE, you can adjust your ride height. Some of the weld in ones are too low and then it's too late.
  9. When you gonna be ready to do it
  10. Illustrious Hector
    Illustrious Hector
    Their bolt on system works best for early Chev
    "Top hat" frames which are better not being welded.
    deathrowdave likes this.
  11. gene-koning
    gene-koning
    So, is Heidt's still producing CE kits, or are they just sending their own stuff out and have eliminated the CE stuff?
    Years ago, Heidt's was using pretty thin material for their kits.
    I haven't been keeping up with the kits for the last several years, but I remember hearing CE closed and couldn't remember who bought them up.
  12. jumbogem29
    jumbogem29
    from Alabama
    Yes Heidts owns CE now . They use 3/16 metal every where .
  13. kvwberg
    kvwberg
    I got one on my 51 ford f1 and love it. I was lucky to get an actual CE kit from Yogi's just before CE sold to Heidts so I don't know what the current kit is like. It bolted on perfectly and didn't require any mods that I remember. The ride is excellent and I haven't had a problem in 4 years.
  14. johnc451
    johnc451
    I have used two CE front ends for years. One is in a 40 coupe. The other in a 51 pickup. Read the instructions and FOLLOW them! I chose to keep the struts rather than go with the no strut application as I figured ford knew what they were doing. Alignment shop found everything dead on. I have them down low and handling is super. Both got the sway bars front and back. Top quality and workmanship on the parts. I have 12 and 10 years of use so far with no complaints.
  15. Jacksmith
    Jacksmith
    from Aridzona
    Not a bolt on, but a weld in on the front. No power steering needed. Rides firm, very tight turning radius, handles flawlessly on the highway @ any speed. Parallel parking is a breeze.
    A bolt on was used on the rear, but I welded it in due to the previous butcher job on the frame. It too, works extremely well.
  16. gene-koning
    gene-koning
    So how long ago did you buy your kits? Was it before Heidt's bought them, or after? I have not heard anything about the CE kits since Heidt's bought them.
  17. Jacksmith
    Jacksmith
    from Aridzona
  18. jumbogem29
    jumbogem29
    from Alabama
    Hey on the CE set up bolt in do you have to notch the cross member to run your flat head in a 40 Ford Coupe anyone have any pictures having done this .
  19. Bandit Billy
    Bandit Billy
    I have heard of it being done (dark web).
    but it is hardly toast worthy.
  20. jumbogem29
    jumbogem29
    from Alabama
    Thanks for the replys
  21. I am pondering this on my 40
    I really don’t like the disc brake kit that’s on it as it pushes the wheels out out 1/2”-3/4”
    While the car rides straight and smooth at the same time it’s very unresponsive while steering .
    I can have a complete kit hub to hub with everything shipped to me for not to bad money.
    Question is. What todo with the steering column?
  22. gene-koning
    gene-koning
    If your willing to change the front suspension to modern stuff, why would changing the steering column to modern stuff be a problem? If the modern looking steering wheel and the modern looking steering column are the issue, you can get a modern steering wheel that looks old, to mount on a modern column that looks old, and your all set. It only costs money. ;):D
  23. rockable
    rockable
    I've shortened and modified original steering columns to work with other front ends. Do some searches. There are quite a few on here. My Buick and Plymouth builds have examples.
  24. Old columns look better
    period
    that modern suspension is hidden under sheet metal. New columns and wheels are in your face
    I’ll do 10 times the work on an old one over a newer one
  25. Illustrious Hector
    Illustrious Hector
    Many great looking cars turn me off when I look inside and see a fat GM tilt colum and equally out of place wheel.
    anthony myrick and Unkl Ian like this.
