Chassis engineering rear end kit with lowering blocks, lower shock plates bending????
Discussion in 'The Hokey Ass Message Board' started by GREASER815, Apr 15, 2012.
  1. GREASER815
    GREASER815
    Got my rear end kit installed, threw in some 2 inch cast iron blocks. Put the U-bolts on, I am in the process of torquing everything down. U bolts say torque to 85 FT LBS so that what I went with. My lower shock plates are bending. I got them to 85, but I am worried I will lose tightness if they continue to bend just from driving. Is this normal for them to curve a bit? I have never had this issue before. My rearend is a 70 Nova, and the ch***is engineering kit I bought is designed to use a Nova rear. Just want to get this done and everything is seeming to go wrong if it can. Any help appreciated.
  2. okiedokie
    okiedokie
    from Ok
    Call CE, very helpfully folks.
  3. The plates look a little skimpy. I don't happen to have any CE units around, but they ought to be at least 1/4" thick but 5/16" to 3/8" would be even better.
    Charlie
  4. RICKY~RICARDO
    RICKY~RICARDO
    from Milwaukee
    I would get some spacers and add them to u bolt section that would prevent them from bending.
  5. Master of None
    Master of None
    Not a bad idea, the plates were probably not designed to be used with lowering blocks. You said the kit was for a nova rear, did you tell them about the blocks? They might have gave you a thicker plate then?
  6. Pewsplace
    Pewsplace
    The photos show a real problem. The plates should not bend under any cir***stance as the u-bolts will loosen and cause big problems. Call CE and send them a photo.
  7. Hitchhiker
    Hitchhiker
    Me too.
  8. turdmagnet
    turdmagnet
    I was concerned about how light they looked when I did my rear axle, so I ended up fabbing up a saddle that wrapped around the leaf springs slightly. It also allows the nuts to be higher up on the u-bolts so you can keep the scrub line nice and high. It also keeps the shock mount higher to accomodate the lowering blocks.
  9. GREASER815
    GREASER815
    I am considering spacers, I just want to make sure they are getting the proper torque. Should I pull the plates up flush them measure and cut spacers a tad bit shorter so I know I am getting a good torque on them?
  10. Jimmy2car
    Jimmy2car
    from No. Cal
    Spacers are not going to help you. The plate is too thin.
  11. joel
    joel
    Some type of spacer is probably the answer. Ch***is Eng. designed the plates to be like the stock ones, i.e. they squeeze the stock Nova mounting rubber pads while the lower plates make contact with the rearend brackets. I can't take pics right now but that's how mine are. 12 bolt rear ( requires multileaf rear spring) stock tapered rubber mounting pads and CE lower plates and U bolts. When installed this way the u bolts can't bend the lower plates.
  12. Those are thinner than ANY CE plates I have seen and/or sold.
  13. Fenders
    Fenders
    x2 !!!
  14. 48FordFanatic
    48FordFanatic
    from Maine
    I thought mine were a little light too. They didn't bend, but then again I didn't tighten them to 85 ft-lbs. Can't remember if mine are 1/4 or 5/16 , but they should probably be 3/8 anyway. Also, I only have about 50 ft-lbs on them . 85 ft-lbs on four bolts in that small an area is one hell of a lot of clamping force....probably not necessary.
  15. chalkboard
    chalkboard
    Bolt holes in the spacers are too far apart. I'm thinking that they shoul be narrower and closer to the width of the springs
  16. oldolds
    oldolds
    What he said.
  17. caseyrod
    caseyrod
    turdmagnet's plate design is the way to go,CE should copy it.I ve never ever torque rear spring u bolts.not that is bad or anything just is not a big deal.
  18. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Agreed, what an awesome design. Apply for a patent, then sell it to CE.
    Greaser's CE setup is bending because lowering blocks were tossed into the mix. Hypothetically, if he kept tightening the nuts, the plates would bend all the way up to the axle saddle. Without lowering blocks, the lower plate should snug up evenly against the underside of the bottom leaf and the axle leaf saddle simultaneously.
    CE will say the kit/plate isn't intended to be used with blocks. And yes, I know....their rear leaf kits seem to always sit high.
  19. BrerHair
    BrerHair
    I'm curious how thick your plates are. My CE plates are 3/8", but I ordered lowering blocks from them. Have not torgued them yet, and now I think I'll just wait and see . . .
  20. GREASER815
    GREASER815
    My plates are just under 1/4" thick. I am going to call them tomorrow, to be perfectly honest, I am not very impressed for the money I gave for the kit. The plates are thin and add just one more issue to deal with. The springs are supposed to be 3" under stock. It sits higher than when I bought it with stock suspension, thats the only reason I even used blocks, I really didn't want to.
  21. spooler41
    spooler41
    Stop; go back and read post #15. Chalkboard had it right. The U bolts should almost touch the spring sides, you need to find spring plates with the proper hole spacing for your spring width. As your picture shows the U bolts are angled out at the bottom and pulling
    to far away from the spring edge. 5/16" or 3/8" spring plates would also help.
    ...............Jack
  22. GREASER815
    GREASER815
    What if I cut another lower plate out of 1/4" plate I have laying around and doubled it up? I could tack the edges, drill my holes, and have myself a 1/2" plate for free. I am trying to get this thing on the road for Tourquefest so I want to solve it and move on. Opinions appreciated.
  23. GREASER815
    GREASER815
    The u-bolts have to come through that wide because the nova perch is spaced out that far.[​IMG]
  24. spooler41
    spooler41
    Greaser, your U bolts also need to be vertical, they look pinched together at the top.
    .......Jack
  25. GREASER815
    GREASER815
    I had them vertical, they wanted to pull in as the plates were bending. I have put alot of rearends in, I just have never ran into an issue like this.
  26. phat rat
    phat rat
    Don't waste your time calling CE. I talked to them in person about the same problem. I have their low ride kit in my cpe with lowering blocks. Their answer was that I shouldn't have needed lowering blocks with that kit and couldn't understand why that wasn't low enough. I added a 3/8" plate to the bottom of theirs but wish I'd put it on top and gained a little for shock extension.
    To those who say the blocks are too narrow or the u-bolts spaced to far apart. The lowering blocks are the width of the spring and the Nova pad. Also the u-bolts go through the stock Nova pad as CE designed it
  27. drptop70ss
    drptop70ss
    from NY
    This is right on, either make spacers to keep the plate from bending up or make the "U" shaped plates. There is nothing holding the plate back from bending further up as well.
  28. readhead
    readhead
    The blocks are to narrow. New blocks. New bolts.
  29. GREASER815
    GREASER815
    Exactly my idea, last time I talked to them ****ed. It was like pulling teeth to spend my money there. Anyway, thats all over and done, I will make a set of thicked plates tomorrow.
  30. Stevie Nash
    Stevie Nash
    I used 3/8 steel when I made mine....
