Chassis Engineering Wanted
Discussion in 'The Hokey Ass Message Board' started by Armyraider64, Jan 23, 2011.
  1. Armyraider64
    Armyraider64
    The wife has agreed that I can start the work on my 53 chevy. I wanted to go with a Chassis Engineering bolt on front end. Where is the best place to pick one up. Are there any Alliance vendors who sell CE? Thanks for all your help. I am very excited to start.<big></big>
  2. Bill Rinaldi
    Bill Rinaldi
    Look in the YOGI'S catalog or call CE, they are in IOWA and they ship stuff all the time. The bolt on kit really works well and the threaded sleeve allows you to adjust height and to "even up" if every things a little off level. If nothing else CE can put you on to a more "local" dealer. Simple Green
  3. Xdrag48
    Xdrag48
    You will really like it.It is the fastest way to do it.A weekend project...
    Steve
    <HR>
  4. davidbistolas
    davidbistolas
    I'll vouch for the kit. I used one in my '51. I installed it in a weekend. I have a build log on my blog.
    http://1951chevy.blogspot.com/
    Jack up the car
    Disconnect steering
    Unbolt old front end & drop it out - then wheel it away
    line up new crossmember, drill a couple of holes, bolt it in.
    done.
  5. Chevy54
    Chevy54
    from Orange, CA
    I ordered mine direct from them...great kit!
  6. I know Vaphead and Alex Gambino are alliave vendors for C.E.
  7. Call them direct and ask for Denny or Jim. Either will be happy to get you set up with a kit.
  8. I have always had a question about their crossmembers. They all come with strut rod braces, do you have to use the braces if you go with full lower A-arms? The braces look like even if you do not use the strut rods they would help keep the crossmember in alignment and tie it farther down the frame to keep it from getting pushed under so to speak. Anyone know if they are necessary?
  9. t-buckethead
    t-buckethead
    from texas
    order the tubular a arms upper and lower and you dont need the strut rods
  10. Armyraider64
    Armyraider64
    Thanks for all of the replies. I went to the Gambino site but did not find any info on the suspension. where would I find Vaphead. Does he have a site?
  11. NumbNutz
    NumbNutz
    Riley Automotive. Under the vendors list. Vaphead is his HAMB name.
    He does offer alliance members a discount. So why not sign up,help the cause, get a discount,reduce global warming and most important - LOOSE THE FNG LABEL
