Hot Rods Chassis Paint
Discussion in 'The Hokey Ass Message Board' started by krylon32, Sep 14, 2022.
  1. krylon32
    krylon32
    from Nebraska
    I'm getting old. Yesterday I read a post with a link referring to a company that sells powder paint by the pound at a reasonable price but I forgot to write the link down. HELP I need this for my 32 Ford sedan project.
  2. '49 Ford Coupe
    '49 Ford Coupe
    Have you thought about truck bed liner paint, finished with glossy? The glossy cancels out the dust collection feature of truck bed liner...
  3. vtx1800
    vtx1800
  4. Roothawg
    Roothawg
    what he said.....^^^^^^^^^^^^^
  5. krylon32
    krylon32
    from Nebraska
    Thanks. That's what I was looking for. I have written it down so I won't lose it.
    seb fontana likes this.
  6. joel
    joel
    If you're not married to powder, I used PPG Pithane with hardener on my avatar. It has a finish that is between flat and satin and is indestructible and covers a lot of imperfections.
  7. Roothawg
    Roothawg
  8. HOTRODPRIMER
    HOTRODPRIMER
    Gary, do you have a local powder coat facility that has a oven big enough for a frame?
    You do realize that this is not a material that sprays like paint, it is a power that is dusted onto the metal and is grounded then coated with extremes heat in a oven. HRP
  9. lippy
    lippy
    from Ks
    I use PPG epoxy. Kind of a semi gloss. Lippy
  10. krylon32
    krylon32
    from Nebraska
    Hot Rod Primer: I've been using powder coating since the early 90's. I am fortunate to have a powder coater about 125 miles away that can do my deuce frames. For this job on the ch***is parts for my highboy sedan I am trying a local coater with a slightly smaller oven.
  11. joel
    joel
    The dealer told me this stuff was used on bridges and iron works out in the weather. It's thick and requires some higher pressure at the gun.
  12. 66 Pontiac Catalina
    66 Pontiac Catalina
    from In a house
    Does it hold up? How long have you used it?
  13. joel
    joel
    Pithane is holding well, I think. It looks like it's been on the frame since 2014. It resists fluids and especially resists chipping. On my '41 truck frame, I had it blasted and powder coated. I think it may be even tougher. It's a local guy that does a lot of industrial pieces.
