Technical chassis paintjob
Discussion in 'Traditional Hot Rods' started by HaroldDegand, Mar 9, 2019.
  1. Doublepumper
    Doublepumper
    from OR-WA, USA
    I use Ospho to etch zinc plating before applying any primer. I've never had much luck just applying a coating primer/paint, to it without it being etched first.
  2. green53ford
    green53ford
    from Wisconsin
    I was a body man for over 60 years and I can tell you lead will not stick to sandblasted metal unless you you grind or wire brush it back down to shiny metal.
    mkebaird likes this.
  3. I send an e-mail to the company who blasted the ch***is.
    Waiting for an answer.
  4. Por 15 will fill and stick.
  5. the flatlander
    the flatlander
    Terrible **** if you ever want to get it off, & ugly too !
    OLSKOOL57 likes this.
  6. light sand blast (not to remove the galvanizing but to etch for adhesion)
    may help cleaning with vinegar, a common household method for cleaning galvanize before painting
    a self etching primer or epoxy may be used to help fill pits
  7. Ppg product CRE would be good to fill the pits. Spray sand repeat.
    Not sure how it will like fresh galvanized/metalized though.
  8. chopolds
    chopolds
    from howell, nj
    If the pits aren't too deep, I'd just shoot a good epoxy, with filling qualities, like HOK's KP-2, 4-5 coats, block down til you hit metal. Repeat if necessary. It's advertised to be able to fill 36 grit scratches, though I hope no one does!
  9. oldiron 440
    oldiron 440
    Sand with 80 grit on a DA and prime with an epoxy. Sand all surfaces thuroly, I use a sand able epoxy.
    mkebaird and Frankie47 like this.
  10. Fortunateson
    Fortunateson
    Yep, Allmetal I believe.
