Projects Chassis Research style dragster/Comp Coupe build flathead powered
Discussion in 'Traditional Hot Rods' started by dragsled, Nov 20, 2011.
  1. pumpman
    pumpman
    Nice job on the blower. Glad to see you're progressing and I hope Beth is healing and soon will be back on the "T". Looks like it won't be too long and you'll be done and ready for some fun.
  2. dreracecar
    dreracecar
    from so-cal
    Boy that was a lot of material hanging off the chuck with so little grab---even with light cuts
  3. roseville carl
    roseville carl
    don't pressurize it Tim I wouldn't want the problems with seals
  4. wrenchbender
    wrenchbender
    Tim that blower must have oil pressure there are no bearings in it it has to have pressurized oil to it or it will seize up in about 3 seconds lol it's like a crank in an engine it has to have oil pressure or it will lock up so it needs to be pressurized and also will have to have a drain on both ends of the blower back in the engine
  5. roseville carl
    roseville carl
    I stand corrected listen to Randy..............
  6. GMC BUBBA
    GMC BUBBA
    WOW never seen a GMC blower without bearings ! Both plates should have good bearings in them and need very little oil to keep them lubed . A small amount of oil up to the bottom of the bearing usually works very well....
  7. wrenchbender
    wrenchbender
    All the 71 and 92 series blowers do have bearings but the 53series is a different breed the only 53 series that has bearings is the 8v-53 the 2,3,4, and 6v-53 has the pressurized style the famous 144 blowers that b&m and weiand and others sell are patterned after the 4-53 that blower will work just fine I ran one on a 283 Chevy and it worked very well it's very important to keep the engine oil changed properly
  8. dragsled
    dragsled
    from Panama IA
    Beth is still healing so I'm doing most of the work on the car till her neck heals all the way, She wants to do the work on her T still so it's on the back burner
    Yeah, Bruce looking at the pics again makes me relize that was pretty dumb , Could have gotten what little brains I have hurt again, don't heal as fast as I used to
    Randy how high up the plates should the oil drains be
    That's right Carl Randy's done a bunch of theses type blowers, 71 type are alot less headache to set up,But where's the fun in that
    Yeah Jim Randy's right no bearings in this type 4-53, , How have you been doing, Back all healed up? Tim Jones
  9. dragsled
    dragsled
    from Panama IA
  10. wrenchbender
    wrenchbender
    Tim the drains can be low from the factory the were at the bottom you already plugged them so it doesn't matter Also how thick of material are you using to build your idler bracket looks to be 1/2" if so you should make it at least 1" thick I've bought and run thinner ones and they always broke or been real hard to keep straight just a thought anyway keep up the good work
  11. GMC BUBBA
    GMC BUBBA
    Yes Tim back is doing ok. Sold my Fuel Injection shop and closed it last Sept. Doing just ignition now , still pretty busy though....
  12. dragsled
    dragsled
    from Panama IA
    Thanks for the info Randy, I think before I ****can this bracket I'll try adding a backbone to it ,I have a triangle piece left from cutting this out I'll weld to the backside, Plus I don't think I have any 1 inch thick pieces left, but I'll check just incase
    As long as your upright and busy all is good ,,,,,,,,, more pics from the work today 102_0183.jpg 102_0184.jpg
  13. Kenneth S
    Kenneth S
    Many years ago my brother built a 4/53 blower, he made new endplates that used bearings, and seals like a 6/71 does.
  14. dreracecar
    dreracecar
    from so-cal
    Tim, Buy cutting away the material at the pinch bolt, you will never get it to hold tight enough because the material wants to bend/pivot in the corner, would have been better to drill and tap into the material and counter bore using an allen bolt for the pinch. also the bore must be pretty much perfect to the dia of the snout (tap on) otherwise there will only be 3 points of contact after you tighten it .
  15. dragsled
    dragsled
    from Panama IA
    Thanks Ken , if this thing works OK I'll do that in the future
    Dug around the shop and found a piece of 1 inch thick Alum, I guess this ones getting hung on the wall
    Thanks for the info Bruce, I'm starting over with a 1 inch thick piece, I'll do the pinch bolt the way you said, any recomendation on bolt size,,, Man for just one guy I sure make alot of s**** alum, LOL
  16. dreracecar
    dreracecar
    from so-cal
  17. roseville carl
    roseville carl
    nothing wrong with s**** Tim, just melt it down and re-purpose it :D:D:D
    give me a call at 916-300-6779 when ya get a chance please
  18. dragsled
    dragsled
    from Panama IA
    Worked on my Y adapter for the dual carbs, pay no attention to my ****ty welds, an hours worth of die grinder time on the inside of the runners an some epoxy, ready to roll:D:D, still might put some port lines on it ,have to see how it runs, My Buddy Roseville Carl sent me out one of his ibler brackets to see if I could use it before building another swing arm one, Doing some rewireing for the new style starter today 102_0215.jpg 102_0216.jpg 102_0218.jpg 102_0221.jpg
  19. 64 DODGE 440
    64 DODGE 440
    from so cal
    Looking good Tim. Nice to see some people are making progress.
  20. dragsled
    dragsled
    from Panama IA
    Nice to get back on this, Between Beth's neck healing and the cold Iowa winter , this things been sitting awhile
  21. 64 DODGE 440
    64 DODGE 440
    from so cal
    Beth's healing is important too. We're keeping her in our thoughts and hope she is healing well.
  22. dragsled
    dragsled
    from Panama IA
    Roseville Carl sent me out one of his idler Brackets , I think we can make it work, for the blower setup,, We got the wiring bugs figured out and Beth finally got to sit in the car with the motor running, Here's the link, Sorry don't know how to embed the vid
  23. roseville carl
    roseville carl
    Uh Tim your video is private need to share it
  24. dragsled
    dragsled
    from Panama IA
    Try it now Carl, not sure if I changed it
  25. loudbang
    Worked fine for me now. And awesome you couldn't have wiped the grin off Beth's face with a snow plow. She better practice up on her emergency egress routine.
  26. pumpman
    pumpman
    Sounds great Tim, Beth looked a little intimidated but she'll get use to it. You're getting closer man!
  27. roseville carl
    roseville carl
    Way too cool Beth!!!! can't wait to see the real grin after your first run, but that grin will have to do for now.
    And Tim that's a cool way of shedding weight off the dragster........................
  28. TheTumbleweeds
    TheTumbleweeds
    from Sweden
    This is AWSOME!!! Sooo much inspiration, just love it!
  29. dragsled
    dragsled
    from Panama IA
    Thanks she's still Grinning, I think when she broke her neck it took some flex out of her:D:D:D
    Well I wouldn't say it sounded great , but it did start:rolleyes:, She'll get used to it, the first time I drove one it scared the **** outta me:eek:
    That grin will last awhile I'd say, ( shedding weight off the dragster)by getting the fat guy out of the seat:rolleyes:
    Thanks you, Now you need to get yours done:D
  30. dragsled
    dragsled
    from Panama IA
    Well just like they say change one thing and alot more follows, My driveline cover was not as easy to use slideing the two pieces together, so I cut in half to make the driveline easier to get at, No problem so far , set up the rear end gears with the coupler ,Then it starts, because with the coupler installed on the rear my 6 inch drive shaft turns out to be 4 inchs, that sets the alinement off about 1/16 on an inch, No room for error without risking breaking something, Soo I unbolt the rear and realine it , weld the mounting holes on the mounting flange shut and redrill them, then remember the driveline cover, now it doesn't fit , time to get the grinder out, ,after that's all inplace I go to mount my new brake master cylinder the newer style is longer than the old one,and won't fit between the lower frame braces on the floor,, So what else is new time to remount the master cylinder, that change makes the brake handle a push type , and if you ever used a push type handbrake when the car is bounceing to a stop ,, Well it ****s, Soo Time to raise the handle braket to keep it a pull type after that I run the brake lines ,, bleed them and all is well,, also made some header pipe covers and added more lights here's the pics, Tim Jones 102_0378.jpg 102_0397.jpg 102_0401.jpg 102_0424.jpg 102_0434.jpg 102_0376.jpg 102_0373.jpg 102_0395.jpg
