Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. jerseyboy
    jerseyboy
    Dumprat,
    Thanks! I have read you can boil them in Simple Green. I was just curious what approach you took.
  2. dumprat
    dumprat
    from b.c.
    I tried simple green, pine sol seems to work better. I stuck them in a 3gallon bucket with about a liter of pine cleaner and tap water and let them soak. It even freed up he little ball at the bottom of the accelerator pump bore. They are usually a ***** to get loose.
    jerseyboy likes this.
  3. dumprat
    dumprat
    from b.c.
    Air cleaner bases made. Fram filters. Bigger than the little ****py Chinese paper ones. Now I just need to design a ***y top. image.jpeg
    brEad, tb33anda3rd, kiwijeff and 4 others like this.
  4. volvobrynk
    volvobrynk
    from Denmark
    Something like this
    ImageUploadedByH.A.M.B.1467960443.448802.jpg ImageUploadedByH.A.M.B.1467960455.053147.jpg ImageUploadedByH.A.M.B.1467960464.978241.jpg
  5. dumprat
    dumprat
    from b.c.
    I thought about that style Volvo but the Thickstun has been repopped and copied to death.
    Not sure yet. I need to let it stew in my brain for a bit.
    brEad and kiwijeff like this.
  6. Runnin shine
    Runnin shine
    Something that ties with your fuel block?
  7. volvobrynk
    volvobrynk
    from Denmark
    Yea it has, but more like your intake and home made would match my expectation for a home build truck, good looking, simple and rugged.
  8. dumprat
    dumprat
    from b.c.
    I was thinking something simple. worried it might have too many finned pieces.
  9. Six Ball
    Six Ball
    from Nevada
    Use a valve cover, cast, stamped, finned, or whatever works. and later when you add a supercharger it'll work as an air box.:rolleyes:
    volvobrynk likes this.
  10. dumprat
    dumprat
    from b.c.
    Na to ratty.
    Revisiting the finned aluminum idea. To much finned aluminum might be like too much bacon, no such thing.
  11. 29Hiboy
    29Hiboy
    Ummm... too many finned pieces???
  12. 29Hiboy
    29Hiboy
    Too slow on the draw. As usual. Ha ha.
  13. 29Hiboy
    29Hiboy
    Sorry but I've so busy on the tub I haven't watched the progress. This is the only pic I have with me.
    bct likes this.
  14. dumprat
    dumprat
    from b.c.
    image.jpeg Functional but ugly. More to come....
    tb33anda3rd and Jeff34 like this.
  15. Six Ball
    Six Ball
    from Nevada
    At least it is not too "Ratty" maybe too "Streatty" but you are a moving target at present. Carry on! :D
  16. volvobrynk
    volvobrynk
    from Denmark
    This look like first step, and I don't care for first step, middle and last step makes a big difference! So shall this!!
  17. dumprat
    dumprat
    from b.c.
    Yes this is just the first step.
  18. Jeff34
    Jeff34
    Cut fins in it?
  19. dumprat
    dumprat
    from b.c.
    Fins are the plan. More later. Fixing off topic junk right now.
  20. dumprat
    dumprat
    from b.c.
    image.jpeg Fins cut now need finishing and polish.
  21. mcyunger
    mcyunger
    hot rodding in its purest form. this is what the hamb stands for. i'm waving my shirt over my head. i just scared the cat.
  22. dumprat
    dumprat
    from b.c.
    image.jpeg And done until I get some stainless wing nuts and redi rod for the tops to attach to. Finned coil and fuel block as well. Might have to make a set of finned side covers and a regulator cover too. I will also need to figure out how to keep all this stuff clean. I am lousy at washing cars or detailing things.
    Woogeroo, brEad, tb33anda3rd and 2 others like this.
  23. bct
    bct
    Are those table saw fins? Or milling machine
  24. dumprat
    dumprat
    from b.c.
    Milling machine. 7* tapered endmill with a .06 radius ground on the end. I cut the fins 3/8ths deep on a 1/2" pitch then stepped the cutter over .010 to climb mill the sides for a nice smooth finish. After demurring I bead blast them and then sand the tops of the fins. I will polish them later.
  25. dumprat
    dumprat
    from b.c.
    This give you a better idea? Table saw fins always look too square. You could try a carbide endmill in a router though? image.jpeg
    ffr1222k, brEad, tb33anda3rd and 4 others like this.
  26. bct
    bct
  27. That's very nice.
    I need to do something similar for triple Strombergs.
  28. 64 DODGE 440
    64 DODGE 440
    from so cal
    Well done! It's always nicer to make your own.
  29. Jethro
    Jethro
    Nice work Matt!
  30. Stogy
    Stogy
    Man your gettin real close to done...You must be getting the itch bigtime. Great respect for you machinists...you can do art with metal...went from streetrod billet to period in a few carefully executed p***es of a machine...this hotrods really coming together Dumprat...enjoying your build...;)
