Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. It’s really coming now eh? Tell us more about the distributor.
    Six Ball and loudbang like this.
  2. dumprat
    dumprat
    from b.c.
    Distributor is a Mallory dual point with tach drive for a Chevy small block. I turned the gears off the end, and shortened the gear section up until the drive tang stuck out about 5/16". I made the adapter tube similar to a hot heads one I borrowed from Jeremy. Mine is just about 1/2" shorter and a tighter fit on the distributor housing. I didn't want to have to use a collar to keep the cam drive gear from walking up and down.
  3. dumprat
    dumprat
    from b.c.
    When I made the new shaft for the cam gear I made it longer to give it more engagement. IMG_1924.JPG
    brEad, Stogy, kidcampbell71 and 9 others like this.
  4. Dude what the hell this build thread is a rollercoaster and I love it. Hemi’s coming out of left field, Jeep parts flying around. It might be low buck to ya, but the game plan behind it is on POINT dude. Killer killer killer work.
    By the way, those small front tires look perfect.
  5. dumprat
    dumprat
    from b.c.
    Thanks @suede55bowtie
    It's a little helper skelter but that has to do with my "what can I find cheap to make this work" mentality.
  6. dumprat
    dumprat
    from b.c.
    IMG_1928.JPG IMG_1929.JPG My buddy Jeremy dubbed this "Frankenstein pan" the name fits. Rails and front are Desoto, rear sump section is 318 dodge truck , and the baffles are 230 Plymouth flathead.
    Holds 8 quarts and I have a small baffle to go in front of the pick up.
    Stogy, loudbang, Six Ball and 2 others like this.
  7. dumprat
    dumprat
    from b.c.
    IMG_1931.JPG Well it looks like I need another flywheel. This one had some weird machining done to it and the friction face has been cut out to clear something in the middle by the bolt heads. You can see the line where my finger is where the original friction face ended. Where it is now puts about 3/8" per side of the clutch face in the air.
    Being that I live on an island I imagine this was a mod for boat **** with a hemi in it. ******** boats!
  8. Stllrng.
    Stllrng.
    Why don’t you make a new flywheel? It will probably be hard to find another.
  9. dumprat
    dumprat
    from b.c.
    Anyone on Vancouver island got a flathead dodge or plymouth flywheel? I had about six of them and gave them all away...... now I need one.
    kidcampbell71 and loudbang like this.
  10. dumprat
    dumprat
    from b.c.
    I thought about that Fred. I don't have access to big machines anymore so it will be. A lot harder.
    I had a sneak peak at your interior the other day. Looks wicked! Love the way your truck looks!
  11. Stllrng.
    Stllrng.
    Thank you! I’m pretty stoked about having a finished interior for the first time. I’m going for the 1960s show car feel. How much swing do you need for your flywheel? I have 14x40 gap bed
  12. dumprat
    dumprat
    from b.c.
    That would do it! I will let you know. Thanks Fred!
  13. dumprat
    dumprat
    from b.c.
    Seems kinda perverse to be doing bodywork on an oil pan? I just want to hide and seal the welds.
    Woogeroo, Stogy, loudbang and 4 others like this.
  14. Runnin shine
    Runnin shine
    I did bodywork on my pickups old 48 backing plates when I put the scoops on. Was that perverse?
    Doesn’t matter now, sold’m to go 2” and self adjusting.
  15. dumprat
    dumprat
    from b.c.
    It's all done and painted. I need to find a good rattle can hi-build primer if such a thing exists.
    Today is set initial timing, install oil pump and pan.
  16. guitarguy
    guitarguy
    It sure does, there may be other brands. SEM 42013, Or Dupli Color EDPP10407
    loudbang and Stogy like this.
  17. dumprat
    dumprat
    from b.c.
    Cool I will have to check that out.
  18. dumprat
    dumprat
    from b.c.
    Installed the Frankenstein pan today. FYI jeep dana 30 diff cover bolts are perfect for oil pan bolts. Self locking and integrated washer.
    But I hit a snag, look like the 354/392 pump shaft is shorter than the Desoto one. So I need to either cut the intermediate shaft down or cut down the oil pump shaft.
    loudbang, guitarguy, Six Ball and 2 others like this.
  19. Six Ball
    Six Ball
    from Nevada
    Cut the one that will be easiest if you ever need a new oil pump.
  20. dumprat
    dumprat
    from b.c.
    I think I am going to cut the Desoto pump shaft down to fit the intermediate shaft. Going to do the play dough length check first, like I should have done first time....
    loudbang and Six Ball like this.
  21. go to Rondex in Nanaimo and pick up some Axalta Spray bomb primer surfacer. I like to say anything in a rattle can is **** but it’s probably the best there is and works good for little jobs.
    dumprat and loudbang like this.
  22. dumprat
    dumprat
    from b.c.
    Getting really tired of playing with engines. Had a few set backs. Most are cleared up. Going to look at a melling m50 pump as my drive tang is a little short on engagement.
    Did get a really nice set of firedome plug wire covers though! Traded them for a pair of finned air cleaners I made for the plymouth six. IMG_1964.JPG
    BradinNC, slv63, Six Ball and 5 others like this.
  23. Runnin shine
    Runnin shine
  24. dumprat
    dumprat
    from b.c.
    The engine stand is bending under the weight of this beast. So I stuck the jack under the balancer to give it a bit of help. Last thing I need is my engine to go crashing to the floor.
    ratrodrodder, Six Ball, Stogy and 4 others like this.
  25. dumprat
    dumprat
    from b.c.
    Hemi is in the frame and clearances are pretty good! Even the generator belt will clear the rad hose. Need to make up a 3/8 spacer to move the trans back but that is easy to do. IMG_1973.JPG IMG_1975.JPG
  26. Tim
    Tim
    from KCMO
    That’s exciting! Looks good man
    dumprat, loudbang and Runnin shine like this.
  27. dumprat
    dumprat
    from b.c.
    Thanks @Tim !
    It's exciting to put stuff together with the intent of making it run, rather than knowing you are going to have to tear it all apart again.
    Runnin shine, loudbang and Tim like this.
  28. Tim
    Tim
    from KCMO
    Yeah I day dream about putting the ch***is together for the “final” time. I love photos of a complete ch***is waiting for the body to get dropped on.
    excited to see this inching closer to the road :)
    Six Ball, Runnin shine and loudbang like this.
  29. dumprat
    dumprat
    from b.c.
    Ya pretty happy about it.
    Spent some time this evening making a 1/4" thick spacer to push the trans back from the adapter plate. As it is I don't have any clutch free play, but I still need to do some reshaping on the clutch fork.
  30. dumprat
    dumprat
    from b.c.
    IMG_1977.JPG 61507727164__474501E2-1D28-4FEA-BD9B-F212B6E2F57B.JPG So if anyone says cutting down a set of cheap Chinese Chrysler headers to fit a Desoto should be easy you have my permission to kick them in the nuts. 8 hours of die grinding, heating,pie cutting, welding , swearing and beating later I have one header that fits and looks like dog ****. The pics don't do it's horribleness justice.
    I need to spend a bunch of time cleaning up the weld spatter and polishing. What ever Chinezium alloy these tubes are made of is super hard to grind after it's welded.
    patmanta, Hotrodmyk, loudbang and 2 others like this.
