Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. Six Ball
    Six Ball
    from Nevada
    I'm trying to sort out my own generator/alternator issue. I like your seat solution a lot. Seat position in my roadster will be a challenge, low enough to be in and not on and hight enough to see out all in a small space.
  2. dumprat
    dumprat
    from b.c.
    The springs and grids seem good. I bout foam on the recommendation of the local"experts" and it's not going to work for what I want. This **** happens every time. These clown think everyone who owns an old car is ok with junk covered in fancy finishes. Leather over cardboard and square seat foam doesn't cut it.
    Stogy and loudbang like this.
  3. dumprat
    dumprat
    from b.c.
    I was going to just order 5" foam no cut my own profiles. The experts said "oh no you need flat foam and a 2" wedge"
    Ya that's ********, unless you want seats like a city bus.
  4. Six Ball
    Six Ball
    from Nevada
    Just when you think the experts know what they are talking about they prove you wrong. :mad:
    You have dealt with bigger problems on this build than the wrong foam. Can you use this for the set back and get what you think will work for the bottom?
  5. dumprat
    dumprat
    from b.c.
    I'm going to see if I can get some 1-1/2" today and add it all together.
    Stogy, loudbang and Six Ball like this.
  6. dumprat
    dumprat
    from b.c.
    Cutting and grinding foam today. I am using the foam I bought. It will work but isint what I wanted and the money is spent. I added bolsters under the sides of the seat. Curved the back edge and glued the pieces together. I might add a roll at the round edge to support my legs a little more.
    Still don't know what to put on the back. I have some 1/2" foam but I don't think it's enough. The seat had felt originally
    Stogy, Drylake, loudbang and 4 others like this.
  7. Jethro
    Jethro
    Are you going to do the s***ching too? The foam looks good , I like the cookie rack seat springs.
  8. dumprat
    dumprat
    from b.c.
    My buddy Jeremy is going to help with the s***ching. I don't have the machine for that.
    Stogy, loudbang and Tim like this.
  9. Roguss
    Roguss
    That cluster is awesome. Nice work on this build.
    Stogy, loudbang and dumprat like this.
  10. dumprat
    dumprat
    from b.c.
    S***ch ripping apart the free leather couch and loveseat for the leather I am going to use. I think the wide s***ch lines should look neat, and different than the same old vinyl tuck and roll. IMG_0335.jpg
  11. dumprat
    dumprat
    from b.c.
    IMG_0348.jpg Filled the rad up! Amazing how much water these things hold. Also amazing how much leaks out when you forget the thermostat housing gasket....
  12. Tim
    Tim
    from KCMO
    What a great shot!
    Gettin awfully close!
    Stogy, Gnater, dumprat and 1 other person like this.
  13. dumprat
    dumprat
    from b.c.
    Thanks Tim. It's a horrible mess but it's all good stuff!
  14. Six Ball
    Six Ball
    from Nevada
    My biggest issue right now is too much good stuff trying to pick the **** out of it.
    The pickup is looking great!
  15. Seat springs are a great idea. The foam is looking good as well!
  16. Tim
    Tim
    from KCMO
    I cut threw the garage every night when I get home from work, I leave just the light in the back on over the front of the A to help me see. I try to get a photo of how cool it looks/ feels like 5 times a week. Never really captures it but now when I see an equivalent photo I get it
    Runnin shine, Stogy, loudbang and 2 others like this.
  17. dumprat
    dumprat
    from b.c.
    IMG_0362.jpg Takes a lot of small bits to get all the wiring done. Not sure I am in love with the back up light but it will blend in better once I get off my **** and get the rear nerf built and installed. I want to get it running and driving first.
    Jeff34, guitarguy, brEad and 9 others like this.
  18. Tim
    Tim
    from KCMO
    Looking good, love seeing all the bits and pieces get put back on
  19. Runnin shine
    Runnin shine
    I love that he is already using it as a truck. Look at that full bed. I tend to use my build as a shelf and another bench to set **** on.
    Stogy, dumprat, Six Ball and 2 others like this.
  20. Six Ball
    Six Ball
    from Nevada
    For me wiring is a huge leap in faith and it is a near religious experience to flip switches for the first time and see things come to life. "Let there be light" :eek:
  21. dumprat
    dumprat
    from b.c.
    IMG_0367.jpg IMG_0369.jpg I dint really want to drill holes in the dash or in my Stewart Warner gauge panel to fit all the switches and ****. So over the last couple of days I built a stainless panel to hold the early 60's ford ignition switch, headlamp switch and the fog light/interior light switch.
    It also helps hide the marine circuit breaker panel for the fuel pump, gauges, wipers and USB phone charger ports. Ya I know it's not stone cold traditional but reality dictates a few things.
    J.Ukrop, Stogy, Gnater and 12 others like this.
  22. Tim
    Tim
    from KCMO
    Looks clean. Any photos of the circuit breaker off the car?
    Stogy likes this.
  23. loudbang
    Cool looks "Store bought" nice work. :)
    Stogy and Six Ball like this.
  24. dumprat
    dumprat
    from b.c.
    Sorry Tim no pics of it off the car. It's a blue sea systems 4321 if you wanna google it. I might change out the cigarette lighter power port for a volt meter.
    Stogy, Six Ball, Tim and 1 other person like this.
  25. dumprat
    dumprat
    from b.c.
    Thanks!
    It's a little rough around the edges but it it's shiny and works!
    Stogy, Six Ball and loudbang like this.
  26. Tim
    Tim
    from KCMO
    Looked it up, looks nice. Are you running the whole truck threw that or is there another dude panel?
  27. Six Ball
    Six Ball
    from Nevada
    Great work, it just gets better. I'm looking forward to wiring my roadster. I got a complete cloth wire kit so the pressure will be on to do it well the first time, planning. :(:D
  28. dumprat
    dumprat
    from b.c.
    I will be running everything except the headlights (they have a fuse on the switch) and the ignition which may or may not get a fuse at all. I need to take a close look at the requirements for the early ford switch
  29. dumprat
    dumprat
    from b.c.
    Took a break from wiring to get the rest of the bed wood installed, then ran out of nuts and washers. So I used that excuse to slobber some fresh linseed oil on it.
    Stogy, Just Gary, DeLuxe 32 and 11 others like this.
  30. loudbang
    Looks good. :)
    Stogy and Nostrebor like this.
