Technical Cheap-Ass Radiators - yes or no
Discussion in 'The Hokey Ass Message Board' started by cederholm, Nov 16, 2023.
  1. cederholm
    cederholm
    Thoughts about cheap radiators like this?
  2. DDDenny
    Maybe not this particular brand but in general a cheap radiator
    sounds like a good way to ruin your vacation!
    LOU WELLS, Lil32, 427 sleeper and 3 others like this.
  3. alchemy
    alchemy
    Where’s the mount for the grille at the top? I’d bet it’s a “close counts” fit, so you might need to do some more fab and welding on it to make it work.
  4. HOTRODPRIMER
    HOTRODPRIMER
    I'm not a fan of aluminum radiators, if you plan on keeping the car why not invest in a copper br***, that's what Henry used and they were meant to last. HRP
  5. 05snopro440
    05snopro440
    Most cheap radiators for the 28-29 A's don't fill the shell opening to the edges which I find looks dumb. How much do you have into your engine? Do you feel comfortable gambling that away on a cheap rad?
  6. HOTRODPRIMER
    HOTRODPRIMER
    They offer a 12 month warranty with a lot of strings attached. HRP
  7. cederholm
    cederholm
    Agreed with all of you. Thx!
  8. larry k
    larry k
    Your answer is NO !!!
  9. Los_Control
    Los_Control
    from TX
    Same time we have been using aluminum radiators in our daily drivers for how many decades?
    Just saying ..... I have one and painted it black ..... works for me.
    maneri, nunattax, Jibs and 15 others like this.
  10. lothiandon1940
    lothiandon1940
    ....Yeah I get it,but that's because they are lighweight and basically a throw-away part.
    427 sleeper, cederholm and jim snow like this.
  11. 05snopro440
    05snopro440
    I use aluminum radiators, and will be using one in my A. Just not a cheap one that is too narrow for the opening and haphazardly glued together.
  12. BJR
    BJR
    I have a Champion aluminum radiator in my Buick for about 10 trouble free years now.
    stillrunners, Jibs, hidez57 and 5 others like this.
  13. Los_Control
    Los_Control
    from TX
    In my case, to have my original radiator re-cored would be over $1k ..... If I could find a radiator shop that could do the job. ....... Radiator shops are becoming extinct.
    I think it is important to get a radiator large enough ... mine is a 3 core and same physical dimensions as my original .... It is thicker though since it is 3 core .....3.5" at the core .... original br*** is 2" thick?
    lothiandon1940 and cederholm like this.
  14. The vast majority of cars on the road run aluminum rads. They put a lot more miles on em than most people here do.
    Aluminum doesn’t have use the same “flu” numbers as copper to work properly.
    My aluminum 2 row cools better than the 3 row copper did. The core is slightly wider for the 2 row.
    I do prefer the look of stamped tanks.
    I vote whatever gets the ride back on the road.
    nunattax, mad mikey, chicken and 7 others like this.
  15. jimmy six
    jimmy six
    I bought “cheap ***” radiator to fit behind a chopped 32 grille that came with a 16” fan. I made a shroud from a cookie sheet and installed a 7” fan all for my race car and it works great. Champion list them by size. There is a 3 gallon fuel tank that mounts on the right side of the radiator. IMG_0249.jpeg IMG_0248.jpeg
  16. Well, yes, they are a throw away part. I had to throw away the one on my OT 31 year, 80,000 mile Buick. A whopping $150 or so to replace the cheap rascal.:D:D:D
    Ben
  17. okiewelder
    okiewelder
    from central Ok
    I ran a Champion in my BBF unibody truck. It finally got clogged up after 13 years and 3 engine swaps.
    cederholm and anthony myrick like this.
  18. tubman
    tubman
    Notwithstanding that the O/P answered his own question in his post, the web page given looks pretty good to me. I particularly like "furnace brazed" and "no epoxy".
    I'd try one.
    ffr1222k, cederholm and 2OLD2FAST like this.
  19. henry29
    henry29
    I've had a champion radiator in my 49 Chevy pickup for 12 years now, never any issues
  20. Mr48chev
    I bought this aluminum radiator for my 48 a couple of years ago and it wasn't spendy at about 250. If I sprayed it with Radiator black it could p*** except for the welding on the seam. It's way heavier than any aluminum radiator that has been on one of my cars and I have had a number with aluminum radiators and it was never the aluminum that failed but the plastic tanks. That was on both Cadillac and BMW.
    This one is a beast and should cool my 292 fine. I've got two 1-1/2 51 Chevy truck radiators that may or may not be good but I wouldn't trust either on a 5000 mile road trip.
    I'm on other boards besides this one and on FB and have not seen actual posts of a Champion failing or not being up to the task even though the negative nannies badmouth them. Those negative nannies always seem to be the ones with a junk used original radiator for sale at a very inflated price.
    8ntsane, mad mikey, cederholm and 6 others like this.
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    How long do they need to last to be considered something other than a throw away part , 5 ,10,20 years , more ??
    cederholm and firstinsteele like this.
  22. X38
    X38
    Company Name: Shanghai Tingyue Auto Parts Co., Ltd.
    I looked it up.
    So, do you feel lucky?
    (or patriotic)
  23. lothiandon1940
    lothiandon1940
    .....Depending on usage and care, I would be setting aside money to replace at 10.
    427 sleeper and cederholm like this.
  24. lothiandon1940
    lothiandon1940
    Not to start this debate all over again (but guess I am), Copper/ Br*** transfers heat better than Aluminum. OK, there we go.:D;)
  25. alanp561
    alanp561
    At the time that Henry started putting copper-br*** radiators in cars, aluminum was expensive to refine. At one time in the development of aluminum, it was more expensive than gold. I will guarantee you that if any of the automobile manufacturers had been able to get aluminum more cheaply than copper or br***, they would have used it. Not to get into a political discussion about this, but the U.S. doesn't produce or import these metals in quan***ies anywhere close to several other countries. If anyone is actually interested, I suggest that they read the Wikipedia articles on how these metals are produced and who does it. You'll be surprised, because it's not always who you suspect.
    As for me, I have a Champion aluminum radiator in my Merc and a 57-year-old copper-br*** Mustang radiator that I paid a lot of money to have modified to run in front of a flathead. It is going in my 29A RPU. When the Ford product goes bad, I'll replace it with an affordable aluminum unit.
  26. Hollywood-East
    Hollywood-East
    Champion is manufactured in California, Great company, Have called several times to have one of there rads , Modified to accommodate different water outlets, Fast delivery as well!
    This topic is about as bad as the cowl steering thread...
  27. flatout51
    flatout51
    I had a walker in my roadster, now have 3 champion rads in my 31 Flathead powered A sedan, 302 powered 48 tudor, and my daily driver 60 f100 4x4 with a 289 and AOD. I'm sold on champion. The 60 will sit in 100⁰ heat with the AC on full blast and the electric fan will cycle with a 180⁰ on 160⁰ off switch. This fall I've had to block part of the rad for the heater to get warm enough!
  28. finn
    finn
    True, all other things being equal.
    Problem is, all other things aren’t necessarily equal. Aluminum fins can be thinner which reduces pressure drop across the core and increases air flow, and the thinner fin transfers heat from the tubes better. In the end, an aluminum radiator, designed properly, does a better job.
    Stock Racer, CSPIDY, loudbang and 5 others like this.
  29. lothiandon1940
    lothiandon1940
    ....So true.:D
    J. A. Miller likes this.
  30. cederholm
    cederholm
    Yeah, I don't think that was a mystery. :D
    50 Merc Man and lothiandon1940 like this.
