Technical cheap bucket seats
Discussion in 'The Hokey Ass Message Board' started by Mario p herrera, Apr 15, 2021.
  1. Roothawg
    Roothawg
    Those should be easy to find.... :)
    Mario p herrera likes this.
  2. looks like lots of aftermarket support
  3. Early Mustang seats seem cheap on craigslist. I p*** over them from time to time 200ish
  4. AccurateMike
    AccurateMike
    Steer clear of the poly buckets if you intend to keep the car. Mine disintegrated to flakes. Never stored outside, had seat covers on them. Got in one day to move it and they crumbled. The covers are still good :) Stuff apparently has a lifespan. After which they return to the granules they started with. The matching rear seat was fibergl*** and is like new. Good hunting, Mike
    loudbang and Mario p herrera like this.
  5. oldolds
    oldolds
  6. stanlow69
    stanlow69
    Get after market Fiber gl*** seats that came in Dune buggy`s. Shouldn`t cost much, plus light weight for shipping. PLEASE, no foreign car seats. This is the HAMB.
  7. Chevy Cavalier around 2000 has a narrow bucket seat that is super comfortable.
  8. Mike Colemire
    Mike Colemire
    Older BMW works out nice, a friend put them in 2 different cars he built. Less than a $100 at a Pick and Pull.
    Elcohaulic and Mario p herrera like this.
  9. 36cab
    36cab
    Mario p herrera and swade41 like this.
  10. stanlow69
    stanlow69
    But Speedway has a really cool museum. Sounds better than buying from an IMPORT place. Even thou they might be the same seat.
  11. AccurateMike
    AccurateMike
    In 1950 almost 400,000 British cars were imported to the US. In 1958 we imported more cars than we exported. With their world renowned reliability (joke), I'm sure there were plenty of imports with narrow seats in the yards of the day. They didn't all get HAMB-friendly g***erplasty surgery. Mike
    Mario p herrera and rusty valley like this.
  12. stanlow69
    stanlow69
    I`m talking about post 65 like the 90`s.
  13. Rocky
    Rocky
    Classified Editor
    '93 Pontiac Grand Am, removed headrests & had covered in buckskin leather. Speedway runners bolted to bottom of seat frames.
  14. gene-koning
    gene-koning
    I used a pair of center bucket seats out of a 2000 something Chrysler Mini van in a 39 Dodge truck cab. They fit fine with about 4" between them and 2" -3" between the doors and the seats. I think I paid $40 for the pair, removed the head rests and made my own seat brackets.
    Take your seat measurements and go to a pull a part and start measuring seats. Gene
  15. Chappy444
    Chappy444
    Early Mazda Miata seats have a pretty flat track (easily modified to flat), have head support, intigrated seat belt,, are not hideous to look at, cheap and plentiful
    Chappy
    AHotRod and Mario p herrera like this.
  16. goldmountain
    goldmountain
  17. rdscotty
    rdscotty
    from red deer
    I always thought these looked like an early racing bucket. fiberglass seat.jpg
    I saw some similar chairs at a thrift store about 2 years ago for $20 each.
  18. Mario p herrera
    Mario p herrera
    They actually do don't they
  19. 36cab
    36cab
    But if you really need them you really need them and if Speedway is out of stock... I am building a 48 Austin g***er so technically I have an import.
  20. AHotRod
    AHotRod
    I agree with "Chappy444" on the Mazda Miata seats, I have used them in the Model A sedan I built, I had the upper head rest area cut off and upholstered in white pleats, looked perfect era correct when done.
    Mario p herrera and Just Gary like this.
  21. jnaki
    jnaki
    upload_2021-4-17_7-9-48.png 1960
    Hello,
    When we were ready for the interior modifications of our 1940 Willys Coupe, we had to make some decisions. The motor was already set back 10% as per street legal rules for the Gas Coupe and Sedan Cl***es. So was the new firewall. Now, the interior got its share of aluminum panels and the LaSalle transmission was given a new cover plate.
    So with this in mind, we wanted some old Corvette bucket seats, but they were too large to move back as far as we could to make up for the 10 percent set back and less room inside. After several hours at the local s****yard searches, we found a small set of bucket seats, from a small sports car. The measurements were within reason, they were comfortable, the surface was still a nice black and the cost was minimal.
    Back then, there were plenty of bucket seats at most s****yards. Something about sports cars, non mechanical/knowledgeable drivers (men/women/teens) made this section larger than most. Good, but, not too good...
    We brought them home, and sat them in the farthest position with the low back almost touching the rear wall under the split window. Once we both sat in the seats, the mounts were put in. This was not going to be a fully adjustable front/rear sliding seat. The room inside of the Willys Coupe was small anyway and with the 10 percent set back, it even got smaller, so the move to the rear of the small cabin was necessary.
    The pedals were still easily pushed and since we installed the interior Moon Tank and Pump, the room for the p***enger was minimal, but doable. (if we pushed the small bucket seats back as far as it would go)
    Jnaki
    I am not sure if you are big and tall or not. So, your motor and firewall may be in the stock position. But, since the interior was on the small size anyway, compared to a larger sedan, adjustments must be made to accommodate the driver and p***enger. Ours was a street legal 1940 Willys Coupe with a 283, then a 292 SBC motor with a 671 supercharger. It was street legal and licensed for such driving.
    We did take it on the street on several weekends, which was outstanding, but it was our entry into the highly compe***ive Gas Coupe and Sedan Cl***es. At first, the 283 put us in B/Gas. Then when we rebuilt a larger 292 c.i. SBC motor and added all blower spec parts + the 671, we were still in B/Gas until we welded in some steel plates to support the trunk area and place the necessary weight over the rear axle for better traction.
    But, our bucket seats were not cheap, just smaller than most. They were comfortable for our weekend road trips around our favorite cruising grounds. Why would you want to buy some “cheap” seats, unless you plan on modifying the seat pattern and give it some new upholstery bolstering. Cheap does not always mean comfort. Comfort is necessary for short or long distance road trips and especially if it is a daily driver. YRMV
  22. Blues4U
    Blues4U
    from So Cal
    Before I bought the seats I posted above I searched for a old pair of British sports car seats for a long time. In the rare instance a pair would pop up the owner thought they were made of gold. They might be a good option, but definitely not cheap, poor availability, IME, yours may vary....
  23. Mr48chev
    Any high back seat doesn't jive in a traditional hot rod. A lot of the early seats like the Dodge A 100 are impossible to find now.
    We used to have a motor home plant close to here that sold the transport seats out of their motor home conversions real cheap but that was a long time ago. A decent but very plain seat that fit a lot of older rigs and didn't look bad.
    I'd agree that if you want cheap you just go to the wrecking yard with your tape measure.
  24. Cheap or period correct, you can only pick one. With skill and perseverance you can find the latter and it won't cost you an arm and a leg.
    Sent from my SM-J337V using The H.A.M.B. mobile app
  25. Mr48chev
  26. stanlow won't like these, but '76-91 Jaguar XJS seats are a good choice IMO...
    Not as nearly bulky as most 'period correct' US buckets, lose the headrest and they look a lot like early Mustang or earlier Brit sports cars; Jag kept 'traditional' interiors far longer than most. Low profile, thin backs, designed for a low seating position and most importantly, comfortable. The seat track mounts to a flat surface. No idea what they're getting for them these days (I've got a personal stash), any you'll find used will need reupholstery but DIY kits in both vinyl and leather are readily available. The one thing to watch for is these don't use a conventional metal lower spring but rather a rubber 'membrane' as a spring. Make sure this isn't bad, although they can be repaired.
    The '89-91 versions have larger side bolsters that can be cut down, the '92-96 versions have taller backs and integrated headrests.
  27. X-cpe
    X-cpe
    The only problem with Fiero seats is they are made to seat you on the floor. If you mount them higher I found the side bolsters roll your knees together.
  28. seb fontana
    seb fontana
    from ct
    Add a bomber seat high back and canned ham [****] you'd have!
  29. seb fontana
    seb fontana
    from ct
    X2 ^^^ I got a pair for my Crosley.
    Blues4U and Mario p herrera like this.
  30. Mario p herrera
    Mario p herrera
    Thank you very informative
