cheap castors??
Discussion in 'The Hokey Ass Message Board' started by Dan, Jan 7, 2004.
  1. Dan
    Dan
    Anyone have a source for cheap casters for things like engine stands and other equipment in the shop??
  2. Roothawg
    Roothawg
    There's a guy that builds those little engine dollies in KS and he told me he knew of a co. that changed all the wheels on shopping carts. He would buy all the old ones in bulk.
  3. a/fxcomet
    a/fxcomet
    from Eugene, OR
  4. OGNC
    OGNC
    The Harbor Freight units work just fine for engines and the like. Anything heavier than a few hundred pounds and you might consider getting a little heavier duty set.
  5. snapper
    snapper
    from PNW
    Our local Harbor Freight store carries a large selection, 3"-14" casters. Check them out. Tool houses and home depot also a good source. Just get some that are not under rated for your load. Nothing worst than to have a wheel bearing pop out, or a caster fail when your cherry picker or engine stand is in use.
  6. zman
    zman
    from Garner, NC
    Also if you've got a Northern Tools in the area or Agri Supply. They both have a great selection.
  7. colorado51
    colorado51
  8. chaco
    chaco
    from Modesto,CA
    Shopping carts work for me. If you live in the "Hood" like me on the 1st and 15th there all over the place.
