Hot Rods "cheap" cooling fan thermostat switch
Discussion in 'The Hokey Ass Message Board' started by onegalonly, Apr 17, 2018.
  1. onegalonly
    onegalonly
    im seeing these cheap cooling fan thermostat switches all over the net costing around $6-$8 .. has anyone used them and are they reliable? the pricier $20 ones look exactly like the $6 ones.. what do you think? and where did you buy yours
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    For 6 bucks I think they are worth a try.
  3. trollst
    trollst
    Put a relay in front of them, it'll last forever.
  4. Mr48chev
    It might be worth a try but are you positive you want to chance the cheap switch not working? Or kicking on at the wrong temp. I'd prefer to spend a bit more coin for one that was designed to kick on at the temp I wanted it to and even then would probably wire in a toggle switch that I could byp*** it with to kick it on manually if needed.
  5. Bandit Billy
    Bandit Billy
    I just wired on up last night. I installed a 185 degree sensor but added a ground jump wire on a dash switch to override.
    pprather likes this.
  6. wheeltramp brian
    wheeltramp brian
    I use em on customer cars.work great
  7. onegalonly
    onegalonly
    no, i don't want to chance the cheap on not working or coming on and off at the wrong temperature.. just figured i ask the hambers to weigh in and see what everyone else is using... i don't want to spend too much coin if i don't have to.. i've seen these in jegs, summit, etc and don't want to pay more because of there name.... im looking for a 200* ON and 185* OFF
  8. Rusty O'Toole
    Rusty O'Toole
    Hell of a note if you blew $6 bucks for nothing.
    Montana1 and razoo lew like this.
