Cheap garage alternative - Cargo Container
Discussion in 'The Hokey Ass Message Board' started by swissmike, Dec 26, 2012.
  1. Wild Turkey
    Wild Turkey
    I used four 20' containers to build my shop. Put them side by side on gravel base, then bolted them together at the front where there's some thicker steel, used a plasma cutter to take out the sides so it's open all the way across.
    I built a roof over them (actually my woodworking shop) and it works great. Even had a pretty hot fire in there and all I had to do was pressure wash the outside and repaint. (inside was a different story)
    If I were to do it again I'd look for the "Hi clearance" ones that are 9-10 feet tall.
    I found mine with a internet search for "used intermodal containers" and asked for "not wind and water tight" to get them cheaper. Fork truck holes are easily fixed.
  2. gimpyshotrods
    gimpyshotrods
    I used to live in a 40' one. I'm weird like that.
  3. barobert
    barobert
    Hello Mike
    When you still have not enough space, so you can give your roadster to my garage.
  4. Happydaze
    Happydaze
    With regard to the condensations issue, i know of a guy who stores a sports car in a container and insdie the container he has one of those bubble car**** things, and it works perfectly.
    Chris
  5. old soul
    old soul
    from oswego NY
    If you look online. They have some cool plans to turn these into camps,homes stuff like that. Its so cool.
  6. bigbstang1969
    bigbstang1969
    Ive used the steel containers and also old refer boxes (short for refridgerator). But I also have a problem with these in my town. So I bought an enclosed 24 foot car trailor to store 1 of my cars. Works out great. The enclosed car trailor has many uses if you remove the car. I have loaded it up and hauled it to fleamarkets also.
  7. 51 BIRD
    51 BIRD
    The basic problem with containers is that they're 8ft wide x 8ft tall. I've wondered about using a "high cube" container which is still 8ft wide,but 10ft tall and laying it on it's side(?)
    you'd have to put down some flooring because at that point,the 'floor' is actually one of the sides. But,one door is now a ramp. Has anyone actually seen this done?
  8. dad-bud
    dad-bud
    Leaky roofs are easily fixed by putting some battens on with some roof sheeting. Simple, low cost and it helps with condensation on the roofs where you have snow.
    In hurricane or tornado-prone areas, make sure you secure these things down to LARGE lumps of buried concrete - they may be 5000 pounds empty but they've got a large surface area and will fly away, along with what you have inside. Jumbo jets are heavier but they fly pretty darn good - it's not weight, it's surface area.
    Anyway, they're a good thing, and pretty cheap too - especially ones that have p***ed their Use-By date.
    Cheers.
  9. bab
    bab
    from nd
    Got a 24 foot van body off a mail truck. It was a life saver when I needed quick storage.
  10. I must live close to Grumpy our zoning doesn't allow containers or transport trailers parked on your property hell motor homes have to be parked behind the frt of the house. but my lot is plenty big I'm allowed to build 4 six unit condos on it
  11. no55mad
    no55mad
    If they are not modified for better ventilation, they get very hot inside (oven like) when closed up and exposed to the sun!
  12. gilby's garage
    gilby's garage
    it the RV storage lot where i used to keep my travel trailer there were many 53' cargo containers that people built in to shops, it's great becauseyou can make all the noise you want to no one around to give you a hard time, i've seen them vented with fans on the roof and A/C units form RV's mounted on top and powered by a generator. one of the guys even has a vintage greyhound bus parked next to his and he lives in it. not a bad gig for $100.00 per month. my travel trailer now sits next to my garage and yes it's packed full of car parts.
  13. denis4x4
    denis4x4
    from Colorado
    Here's my 20 footers with a monitor roof to match our other buildings. When I bought mine, gave them the Sherwin-Williams code to match the paint on the house. The overhead storage is real handy and the containers do not turn into sweat boxes in the summer. BTW, my floors are hardwood.
    No permit needed as they are "temporary". Containers, custom trusses, roofing and labor came in under ten grand.
  14. Uncle Bob
    Uncle Bob
    from Salado, Tx
  15. mlagusis
    mlagusis
    Maybe drill some 1/2" drain holes in each corner just in case???
  16. junk yard kid
    junk yard kid
    heres mine right after i finished it up. It looks a lot more used and has more stuff around it now. The fronts of the boxs are painted black as well to hide them more.
  17. Frankie47
    Frankie47
    from omaha ne.
    Drain holes become mouse holes...........
  18. gimpyshotrods
    gimpyshotrods
    Quarter-inch thick perforated metal.
  19. Nads
    Nads
    from Hypocrisy
    Dexter killed his last victim in one of those
