Cheap T Rearend
Discussion in 'The Hokey Ass Message Board' started by JCook5003, Jun 16, 2008.
  1. JCook5003
    JCook5003
    Hey Guys-
    I'm starting my cheap T build and I am gathering parts, I need some recommendations on what rearends to look for, seems like a Ford 8.8 might be good, the truck that I got the 300 inline 6 from has a Ford 9 but I think it might be to wide, it's an 80 model F150,
    Anyway recommendations? Suggestions on the Ford 9 from the F150?
    Thanks
    Josh
  2. brucer
    brucer
    from western ky
    i would say if your anywhere near 65-68 inches drum to drum you should be fine... you can adjust with the backspacing on your wheels...
    try this site, i'm a member, its a T-bucket based forum. alot of experienced builders and Tbucket projects galore.
    http://www.tbucketeers.com/
  3. JCook5003
    JCook5003
    Thanks, I'll have to check the F150 axle from drum to drum
  4. brandon
    brandon
    80's 2wd toyota pickup ....55ish and 57ish widths...4.5 pattern ...plenty of them out there... brandon:D
  5. JCook5003
    JCook5003
    Yeah it seems that f150 axle is about 62 inches wide......to wide for a skinny tire modified?
    thats true lots of toyota pickup axles around, if I pckup a 4x4 its got 4.10 gearing.......I'm not sure if the 4x2 has the same gear or not?
  6. brandon
    brandon
    pretty sure alot had 4.10's....4x4's are 6 lug though....
  7. JCook5003
    JCook5003
    This is true, after research I think the Ford axle is to wide......I want to run tall skinny tires, I might look for a toyota axle now, I think I can scrounge one cheap.......
    Also anyone know a length on a ford inline six 300? from say fan to bellhousing mounting surface?
  8. brucer
    brucer
    from western ky
    ok i figured you were going wide tires the f150 rear is pretty wide...
    try an s-10 rear, alot run them.. or maybe an 8.8 from a ranger.. look for the 4 wheel drive units, they'll have limited slip and a decent gear ratio already
  9. Omega
    Omega
    from Mass
    toyota 6lug is the same as chevy, which you can use 6lug 60's steelies if you had to. Just throwing that out there.
  10. Codeman
    Codeman
    from SE Mo
    2wd is a 5 on 4.5 just like Ford car/ Ranger.
  11. Ole don
    Ole don
    89 and 90 Ranger 4x4 is about 58 5/8 wide, mine came with 3.73 traction lok.
    The 4 cylinder 5 speeds came with 3.45, but they had small brakes. The brakes are interchangable if you do backing plates and drums off the bigger Ranger.
  12. Shifty Shifterton
    Shifty Shifterton
    I would personally stick to the front-loader style like an 8" or 9" ford. There are others out there, 50s chevy and 70s chrysler come to mind. They have the smooth housing back, which IMO just looks better on something like a T where it's very exposed. Don't make the guy behind you look at a diff cover........
  13. JCook5003
    JCook5003
  14. brandon
    brandon
    the 'yota is a front loader...got one in my track t "project"...
  15. tjm73
    tjm73
    Didn't you already post a similar thread?
  16. noclubjoe
    noclubjoe
    my t bucket has a 56 chevy rear end in it. the look from the rear is perfect not too wide or to skinny but my car was also bulit in the later 60's when a tri-5 rear was easy to find and didnt cost your right arm for parts.:D
