Cheap Truck bed for the Nugget
Discussion in 'The Hokey Ass Message Board' started by Antibilly, Feb 4, 2005.
  1. Antibilly
    Antibilly
    When I recieved the Nugget from Bubba it had a old sign tossed in the back for a bed. It worked but read RV PARKING! Know how much the proper wood kit cost I decided to take the low road aka low budget.
    I have $15.00 invested in the bed so far. Im gonna paint it as well but have decided on a color. Any help? enjoy the pics and my new flooring ake truck bed!
  2. See if ya can find some copper naphthanate,,,,not used much anymore ,but is kinda a greenish stain look and was used on canvas,wood, and rope as a water repellent. HRP
  3. Terry
    Terry
    Man that thing looks great, I think I'd seal ot rather than paint!
  4. joeycarpunk
    joeycarpunk
    from MN,USA
    I agree, a clear coat would look awesome.
  5. hankcash
    hankcash
    That looks good, but wait 'till you see the truck bed that Bubba put in the green bean!
    HC
  6. Antibilly
    Antibilly
    hahahahaahaha I bet he would
    I was thinking some type of water seal as well! Kinda like a thompsons whater seal?
  7. zman
    zman
    from Garner, NC
    I'm voting for a coat of Urethane and run it.
  8. carlingas
    carlingas
    go clearcoat..you can always paint it.besides, the clear will work as a primer for the wood to cover with less coats of paint.
  9. Antibilly
    Antibilly
    the pictures make it look better then it is I think.
    I used a sheet of plywood cut down and drilled a hole for the extra tank hose..then ran to home depot and got some trim piece for the edges. I gues there for base boards in your home.
    oh and a box of wood screws!
  10. Nads
    Nads
    from Hypocrisy
    That looks really good.
    I've dyed wood before with aniline shoe dye, it comes in a million different colors. You can clear coat it with urethane and it looks like candy apple.
  11. hankcash
    hankcash
    Paint a mural of Nads on it and clear grip it!
    HC
  12. atch
    atch
    draglink,
    you're in florida. deck varnish. 'nuff said.
  13. Antibilly
    Antibilly
    DEAL!
  14. Both sides! or it'll just rot fron the bottom.
  15. hankcash
    hankcash
    Toss a couple of old tires on it so it don't blow away when the winds kick up!
    HC
  16. Damn Mike I was expecting some ragidy ol' mattress you found under some ol' overpass. All stainy 'n' sticky. ;)
    Looks good. :cool: I'm just wipeing mine down with Dutch Oil, but mines a go and bring it back truck. Not nearly so smooth and the nugget.
  17. Antibilly
    Antibilly
    hahahah to funny beaner. the first thing my son said when he saw it was just that.
    DAD we can put a matress in it and camp out
  18. seymour
    seymour
    from PNW
    hahaha... that rules
  19. Antibilly
    Antibilly
    I just got back from ACE and ended up buying a pint of
    Polycrylic protective Finish Clear Gloss
    Im off to see how it turns out
  20. Django
    Django
    from Chicago
    Don't forget to do both sides! Keep an eye on the bottom side if you plan to drive it in weather much.
  21. Antibilly
    Antibilly
    its a cheap plywood bed...who cares if it rots in a year. Ill build another! hahaahh
    its in there now and aint comeing back out
  22. Hey Mike. Looks good. A good Sapr Urethane will hold up good. What's under the wood? If there is any bare metal under the wood, the wood will hold water, and rot out the bedfloor. Major rust problem... I'd treat the bottom side of the wood if possible...
    Speaking of rot, You should see the bikes here! The ocean water has fucked everything up good. We lost our carport here at the condo 2 weeks ago. The aluminum cases on the bikes are all corroded to shit. I went out today to go for a ride and the clutch cable snapped! Talk about corrosion, Florida is bad!
    How's the trailer coming? I'll stop by and get those hubcaps soon...
  23. Goozgaz
    Goozgaz
    I've got a sheet of plywood fora bed also.I was thinking of using stick-on floor tiles to cover it. They are about $1 sqft (or less) They come in 1 ft square tiles and come in a lot of diferent looks and patterns
  24. Antibilly
    Antibilly
    Good idea
  25. slammed
    slammed
    You may spray the underside w/ Rubberized undercoating. How about some old pic's of '50's ride's and pin-up gal's cleared over? An old pic of the Nugget casino and some cocktail napkin's, poker chip's, ect. would be an idea.
  26. Espi
    Espi
    from Arizona
  27. Nads
    Nads
    from Hypocrisy
    I really like slammed's idea of putting pin up girls on the plywood, that would look tits......get it?
  28. Jake H.
    Jake H.
    Oh shit! I thought the post title said something about Cheap Trick and Nugent. I personally like Live at Budokhan. And the 'Nuge never disappoints. Must've been your Joe Dirt avatar.
    Oh yeah, the bed is a budget rodder's wet dream! Looks good.
    Jake
  29. Antibilly
    Antibilly
    1st coat applied
  30. Antibilly
    Antibilly
    830am coat two applied!!
