cheapest place to get a flathead waterpump?
Discussion in 'The Hokey Ass Message Board' started by hooligan909, Oct 12, 2010.
  1. hooligan909
    hooligan909
    from San Diego!
    hey so i have done some researching but just seeing if anyone knows of a cheaper place. My wife has a 53 ford with a 239 in it. the passenger water pump started leaking pretty bad.speedway has them for $89 a piece but just checking if anyone knows a place that's cheaper.
    Thanx
  2. edwardlloyd
    edwardlloyd
    from Germany
    And people wonder why everything ends up being made in China and everyone loses their job.
  3. aaggie
    aaggie
    Cheap is not always the way to go. There are places that sell rebuild kits as well if you have access to a press and the housings are OK. Try the folks at Ford Barn.
  4. 8-Track
    8-Track
    try little dearborn in mpls, mn
  5. low-n-slo54
    low-n-slo54
    or an unattended car withy a flathead.
  6. I'd rather look for the best water pump:)
  7. studhud
    studhud
    Um spend the money and ya might not be on the side of the road or your wife overheating jusy my 2 cents
    Dave Hitch
  8. AJofHollywood
    AJofHollywood
  9. Francisco Plumbero
    Francisco Plumbero
    from il.
    Cheapest est is not best est est, maybe shitty est est though.
  10. 4t7flat
    4t7flat
    Buying the most expensive pump does not garantee its the best. I bought a pair of 59AB pumps from Flathead Jack,they failed(siezed up) at 6000 miles. When I had them rebuilt,the machinist said the bushings were made of plain brass,and not Oilite bronze,like original. I don't trust anything Speedway sells,no matter the cost.
  11. This is definitely true....So what are the best?
  12. thunderbirdesq
    thunderbirdesq
    macsautoparts.com
  13. LukeH1
    LukeH1
    Bob Drake $130 for two pumps
  14. tubman
    tubman
    What he said, and replace them both when you've got the engine up in the air.
  15. RAY With
    RAY With
    Cheap is not the answer to Flatty's water pumps. I have a set of speedways new pumps on my flatty going on 5 years and no problems at all.bearings over bushings any day is the way to go.
  16. Petejoe
    Petejoe
    from Zoar, Ohio
    I heard Napa is now carrying the newly designed bearing waterpumps. Really reasonable. Regardless of where you choose dont buy the old style pumps.
  17. T Weed
    T Weed
    I've bought a set from NAPA in the last coupla years, dont recall what they cost but they are still working good...
  18. flthd
    flthd
    Got my pumps from macs, said nascar engineered seals and bearings, gotta be good right? heh
