check out this kool f100 on ebay
Discussion in 'The Hokey Ass Message Board' started by Kustom7777, Feb 17, 2006.
  1. Kustom7777
    Kustom7777
    from Austin, TX
    take a look at this truck,,,,does a hamber own it??
    ebay item # 4614370678
    dont know how to post this as a link,,maybe someone can help..thx
  2. CHOPMERC
    CHOPMERC
  3. 57JoeFoMoPar
    57JoeFoMoPar
    Gonna have to agree with Bobby here, but orther than that this truck is dead on
  4. Slag Kustom
    Slag Kustom
    cool truck but the skirts have to go.
  5. zman
    zman
    from Garner, NC
    Where do you put the parts you're hauling? :eek:
  6. muffman58
    muffman58
    Sweet! But one thing baffles me, why is the A/C compressor piped into the valve cover? Is it a joke? Or a way to have a COOL motor? If you look you`ll see that the compressor clutch is wired up!
  7. bluebrian
    bluebrian
    from dallas
    went back an looked and that is the oddest thing. I can't tell if the other A/C lines are hooked up. I wonder what that does. Maybe its just venting into the compressor. But that wouldn't make sense either. Im scratching my head over this one.
  8. Carshowlvr
    Carshowlvr
    from Florida
    Hot damn. I like it just as it is, the skirts are different for sure, especially with those scoops. I love a truck with tail fins. Too damn far away to check it out in person though.
  9. Here's my guess on the compressor and hose to the valve cover. He is obviously using the compressor to pump his air bag suspension, so yes the compressor is working. The line to the valve cover would be an oil return line as my guess.
  10. Hackerbilt
    Hackerbilt
    Can't be an oil return...too much of a loop in it.
    I don't think the rotary style pump actually uses an oil feed or sump anyway. It uses oil suspended in the refrigerant to lube the bearings.
    Perhaps he's drawing his air INTO the compressor thru the engine to pick up some oil vapor and help keep his bearings from burning up...
    Wouldn't oily air degrade the lift bag rubber over time?
    4 wheelers with homebuilt OB Air setups use those pumps but circulate that special oil (forget the name!) that bonds to the metal...then drain it completely and run it dry till it dies, rather than oil the tires and tire beads. All the traction in the world won't help if your smokin' your beads or popping the slippery tires off the rim! LoL
  11. Thirdyfivepickup
    Thirdyfivepickup
    Wired up and routed quite well, I may add...
  12. Polara
    Polara
    from Indy
    It's a homebuilt crankcase vacuum pump, to get every last horsepower needed to cruise at 7mph.
  13. pretty cool looking......not really into all the tilt bed and hood thing.
  14. I think you might have something on the oil feed. You're right about the loop. Since there is no longer refrigerant, there needs to be some source of oil. It doesn't require much and the oil vapor may be just enough. I've seen OBA systems on 4 wheelers that just use a drop or two of light engine oil. Most quality systems I've seen have an oil separator and a return line so you don't mess up your entire system with oil. I assume he has something similar here.
  15. Rocknrod
    Rocknrod
    from NC, USA
    That ac setup is strange...
    I've heard of running a vacuum pump on the crankcase for power, but never a little foam covered PCV valve line to the AC compressor! haha
  16. Hackerbilt
    Hackerbilt
    Yeah...good point! ;)
    An oil separator in the system would be easy enough to rig!
    I suppose there's a pressure tank somewhere in the system anyway so the separator wouldn't have much problem dealing with the small amount of oil still in suspension after that. Most would just remain in the bottom of the pressure tank for easy draining.
    Seems like the guy had a good idea if he worked all the bugs out! :D
  17. gregg
    gregg
    from Fulton IL
    I emailed him & he was nice enough to respond right away. He says it's for the airbags. The pump picks up enough oil through the valve cover to stay lubed. I forgot to ask if he's a HAMBer.
  18. muffman58
    muffman58
    Well you learn something new everyday!
  19. oldskool55
    oldskool55
    from socal
    i dont know if hes a hamber but i know hes on the ruff rodder board
  20. Cool, thanks for confirming that. Hackerbill was right. I might get an assist!;) :D
  21. =mike=
    =mike=
    you guys are retards . trucks with skirts rule . period . Those scoops are *takemorleavem* but everything else is pretty right on the money except for the dopey images on the dash . . lose that shit . . . . Otherwise that truck is fucked up , and cool as hell . suckit trebek .
  22. The_Monster
    The_Monster
    The images on the dash actually caught my eye, as "Woh, thats kinda cool" in a different way.
    reminds me of an old 50's TV tray or a drive-in restroom wallpaper or something. I like it only cause its different and unique. never seen that done on a dash before.
