Check your sh*t guys!!...
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, Oct 30, 2009.
  1. 3wLarry
    3wLarry
    from Owasso, Ok
    I'm doin' 65 down the hiway this morning on my way to my buddies shop to get a laundry list of **** fixed on Franke.
    Get there and proceed to tell Roger everything to be done, and the last thing on the list was the rubber brake pad came off...he says I'll do that right now...
    ...he grabs the pad and wrestles with it a bit and then says "WTF"!...he's standing there with the brake pedal in his hand! :eek:. Seems the nut had backed off on the bottom, and had fallen off.
    Ha said the only thing that saved my *** was the fact that the pedal is knurled at the bottom and was wedged in and only came out while he was jerking on it.
    How many miles had I driven without that nut?:eek:
    kidcampbell71 likes this.
  2. makes a good point
    check out the stuff that other have done
    tk
  3. WOW! Lucky man!!
    Check your sh*t guys!!... But for the love of god wash your hands well after it!:eek:
  4. -Brent-
    -Brent-
    Wow man, that's nuts.:eek:
    Cool pic, Larry. I miss trees and gr*** that doesn't need watering.
  5. good point,Im going over my 56 from head to toe lately,it was stored for about 30 years and Im findin all kinds of **** that needs attention including NO coterpins in the end of the draglink,,,,,,,,,,,,CYA fellas!
  6. duckman rob
    duckman rob
    from NW Indiana
    that would ****
    it always funny till someone loses a nut
  7. thunderbirdesq
    thunderbirdesq
  8. Deadbird
    Deadbird
  9. Von Rigg Fink
    Von Rigg Fink
    from Garage
    thats not good..
    i have told myself that when i get my A build done , there will be a day before it goes anywhere out of my shop, that i sit down and go from one end of the car to the other tightning every screw and bolt before it goes out for its first run..or at least putting a wrench on each one to be sure it hasent been forgotten
  10. oj
    oj
    Theres alway something ready to fall off these things and its' our job to find'em. You know that clevis bolt that goes thru the MC shaft rodend and into the brake pedal arm? You have any idea how many of them i have seen without a cotter pin? I always check them before a car leaves the shop.
  11. 40StudeDude
    40StudeDude
    Beginning in early spring, I check everything that moves, turns, rotates or generally spins in my car...that includes tightening pan bolts, valve cover bolts, water pump bolts, fan bolt and alternator bolts...as well an anything under the car that does the above...and that includes wheel bearings...
    Ya know, there's over 130,000 miles on my old Studey...and not once did I have to replace anything out on the highway because a nut fell off...oh wait, I lost my club plaque in Joplin once...but it wasn't becuase the nuts fell off...that damned chain broke...!!!
    Make it a point to go over your car in the early spring...especially if you do as much highway driving as I do...!!!
    R-
  12. bigken
    bigken
    3W, be careful with your nuts, your gettin' old, ya know. Last thing you wanna do is loose a nut while drivin'. thanks for the advise.
  13. 49ratfink
    49ratfink
    I jerk on it to check my nuts a couple times a week.:D
  14. B.A.KING
    B.A.KING
    roflmao!!! my wife tells me to quit checking my nuts,go figure:rolleyes:
  15. dullchrome
    dullchrome
    from SoCal
    I had something similar happen to me. I left the house one day and rolled through the stop sign at the end of my street and got "lucky" with a green light onto the freeway. Only to find out that I had no brakes when some jaggoff cut in front of me. Downshifting and pulling the e-brake were about all I could do to stop and that took quite some time. It ended up being a brake line that had rusted through under one of the hold downs on the rear axle. A little preventative maintenace goes a long way.....check yer **** out guys!
    P.S. I did leave some pretty cool striping down the freeway from trying to pump the pedal, the break fluid left marks there to remind me of the event for over a month.
  16. onlychevrolets
    onlychevrolets
    no kidding...
  17. chaddilac
    chaddilac
    I'd check both nuts larry!!!:D
  18. G V Gordon
    G V Gordon
    from Enid OK
    One of the reasons I think an emergency brake is a good idea in all cars. Saved my *** on a couple occasions over the years.
    When did they stop calling them e-brakes and start calling them parking brakes? Was it when dual M/Cs came out. Just curious.
    Glad you found that in the shop instead of the hard way Larry.
  19. MEDDLER1
    MEDDLER1
    I had the exact same thing happen to me too.I know I am due for the annual go over for sure.Thanks for the reminder.
  20. Hank37
    Hank37
    I've seen this happen, pull back on your brake pedal to the stop and the push rod to the master cylinder falls out the back of the piston. Whoa ,no brakes. The fix is adjust your pedal arm stop so rod can't fall out of piston
  21. BuickBorracho
    BuickBorracho
  22. Dooley
    Dooley
    from Buffalo NY
    Just had my ****** linkage come off, the bolt that holds the link from the shifter to the arm on the ****** came off.
    Manual shift PG was stuck in first, I had to (with the car running) push it into drive to get home...
  23. swi66
    swi66
    My wife drives a 97 Subaru Right hand drive to deliver mail, she's a postal worker.
    600 stops a day, mailbox to mailbox.
    In any event, one day she said to check the car the brake pedal felt "wobbly".
    I had no idea what she meant by wobbly so I bent down and grabbed the pedal and the pad came off in my hand..................metal and all.
    It was rotted underneath the rubber pad from all the salt getting dragged in with the feet in NY winters.
    Who would have thought!
  24. tinmann
    tinmann
    While you're checking your nuts, Larry, you might as well turn your head to the left and cough. Multi-tasking.
  25. 3wLarry
    3wLarry
    from Owasso, Ok
    cough
  26. 18n57
    18n57
    The nut holding the steering wheel can be seriously flawed sometimes:eek:
    Glad your episode didn't result in carnage....
  27. squirrel
    I was afraid to open this thread because I thought it would be about prostrate exams
  28. povertyflats
    povertyflats
    from Missouri
    I had a late model Jeep Cherokee clutch pedal break off one time on a low mileage unit. Scared me, but no big deal. Robot welder must have had a hangover that day. Old great aunt of mine had a steering wheel come off while driving back in the 60's in Oakland, CA traffic. Somehow she survived too.
  29. BBobb
    BBobb
    Small world,i went to a little car event last saturday here local.For some reason the day before i decided to put the model a up on the rack to look things over for the first time since i built her over a year and a half ago..............WHAT I FOUND WOULD SCARE THE HELL OUT OF A FELLA!!!. I found myself wrenching miss items for over an hour.Bet your *** i won't wait so long again
  30. unkledaddy
    unkledaddy
    Nothing like a pre-flight walk around.
