Technical Check your tires on your car!
Discussion in 'The Hokey Ass Message Board' started by 54 Chevy, Apr 20, 2015.
  1. clem
    clem
    Common sense goes a long way, as does experience. In 37 years, with multiple cars I don't remember having had a blow out. I NEVER run recaps/ retreads. ( post 63 looks like a old recapped snow tyre, generally lower speed rating, but I may be wrong). I only run fabric belts as we drive on metal/ stone/gravel roads. Generally check pressures every month to six weeks or visually every couple. As some one once said - Common sense is not all that common!
    Model T1 likes this.
  2. The chunk flew off when I was doing 50 MPH I likely couldn't find it! I owned ad drove semi trucks for many decades. We would run bias ply tires until the became smooth as a gut. Then we would regroove them with a hot regrooving tool from JC Whitney and run them some more miles.
  3. I reciently came up with some 16 inch 6 lug split rims. I mounted some old 14 ply bias tires on them and put them on my tilt top trailer. Those tires have a 3750 single load weight rating. They have 80 lbs of air pressure in each tire. ought to handle moving a backhoe.
  4. Post 63 looks to me to be a radial. I commonly run aged bias ply. aged radials don't last very long. if you change the direction of rotation of a radial it will quickly fail. if you let a radial set flat for a few days it will quickly fail. Radial tires ride and handle better than bias ply.
  5. loveoftiki
    loveoftiki
    from Livonia,Mi
  6. Model T1
    Model T1
    About 24 years old I'd guess.
  7. 54 Chevy
    54 Chevy
    with the cost of semi tires I don't blame you.
