Technical checkerboard, what size?
Discussion in 'Traditional Hot Rods' started by oj, Jan 14, 2020.
  1. oj
    oj
    I'm doing a checkerboard firewall and need opinions for the perfect size squares, its a model T firewall, not very big.
    The body a gloss black with eggshell white checkers.
    Any opinions?
    thanks, Oj
    chryslerfan55, Dino 64 and Just Gary like this.
  2. lothiandon1940
    lothiandon1940
    Since it's a relatively small area, the squares can't be too big, yet they can't be so small that if you walk 10 feet away the firewall just looks grey. I'm thinking 3" squares.
  3. lothiandon1940
    lothiandon1940
    Just curious, what are the dimensions of the "T" firewall? This could help with the decision making.:D........Don.
  4. oj
    oj
    You won't see much of it:
    I was thinking an inch? square?
  5. rustydusty
    rustydusty
    I would go with 2". Did a checkered racing stripe on a small block powered '66 Spitfire I had a few years back. The wife said it looks like a taxicab...
  6. Desmodromic
    Desmodromic
    IMO, small enough so that it looks grey from 10 inches; or better yet, gloss black.
  7. Peter Nowak
    Peter Nowak
    ABD2CFC1-8F1D-494F-9859-6476B41D2984.jpeg Several threads exist on HAMB with pics. They may give you an idea of sizes.
  8. wild32hotrod
    wild32hotrod
  9. oj
    oj
    For some reason the checkers shout 'English' to me but I don't know why. Fun car.
    lothiandon1940 and Dino 64 like this.
  10. Dino 64
    Dino 64
    from Virginia
    Two inch looks good to me
  11. hotrodjack33
    hotrodjack33
    3 inch.
    The easiest way to checkerboard a firewall...and to get the spacing right is:
    Horizontaly cover the entire firewall with tape with each strip of tape almost touching. Then remove every other piece of tape.
    Vertically do the same, cover the entire firewall with tape and remove every other piece
    This will give you 2/3ds of your squares. you will have to X-acto knife out the other 1/3 of them. You will only have to cut 2 sides of the remaining 1/3 squares to remove them and the existing tape will act as a guide. It's easy:D
    Hope this helps
  12. rusty rocket
    rusty rocket
    How about so small you can't see them. Sorry I'm not a checkered firewall fan, to me it seems cheesy. It's your car though, have fun with it.
  13. Budget36
    Budget36
    Depends on the size of the checkers you play with. Good thing is under normal conditions if you decide to play chess, the bases are smaller than checkers when bought in a set.
  14. Dino 64
    Dino 64
    from Virginia
    Considering the small area visible with the engine in, I think smaller rather than large. I think you would loose the pattern if they are too big in a small area. My 2cts
    oj, lothiandon1940 and Just Gary like this.
  15. 2" is easy to do, just get 2"tape.
    chryslerfan55 and hotrodjack33 like this.
  16. swade41
    swade41
    from Buffalo,NY
    Get some black duct tape and a piece of posterboard, mock it up and see what it looks like
    Just Gary likes this.
  17. hotrodjack33
    hotrodjack33
    And 3" is also easy to do, I used 3" masking tape.
    And by the way Lloyd, what the hell is KTBF ? I racked my brain trying to make a clever guess...all I could come up with is Kitty *** **** ****er:eek::D:eek::D
  18. Pete Eastwood
    Pete Eastwood
    from california
    small enough, so you don't see them .
  19. Chili Phil
    Chili Phil
    As long as you glue some checkers on it. Or even, chess pieces.
  20. Hnstray
    Hnstray
    from Quincy, IL
    @oj ..... My choice would be the size that just one square would cover the entire firewall...;)
    Ray
    guthriesmith and lothiandon1940 like this.
  21. Just Gary
    Just Gary
    Sam Foose liked 'em back around 1978 (I think) before "traditional" was cool.
    His look like maybe 2" but I think size would depend on how much of your firewall is visible.
    Sam-Foose-1948-Ford-Business-Coupe-Vintage-Custom~3.jpg Sam-Foose-1948-Ford-Business-Coupe-Vintage-Custom~2.jpg
    Dino 64, oj and lothiandon1940 like this.
  22. Damn! You're the first to figure it out Jack! lol.... not my idea, but it's KEEP THE ***** FLOORED! I've got a bunch of those shirts. Screenshot_20200117-072126_Gallery.jpg
  23. oj
    oj
    Jeez guys, its a fukin HOTROD! we don't do stodgy in Virginia!
    Just kiddin, it is a tough decision, the car already has a ton of stuff going on and I might be cluttering it up with the checkerboard. On the other hand, I've come this far and probably won't again; I don't want to look at the finished product wishing I'd gone checkerboard.
    If I don't go checkerboard it'll be an off-white like D-Russ' firewall, crisp and clean.
    Dino 64, lothiandon1940 and Just Gary like this.
  24. oj
    oj
    I think thats a good idea, I'll get some different color masking tape of different widths and do a mockup while the body is off the car, post some pics and we'll see whats what. Gonna snow tomorrow, sound slike a good day to lay down some tape.
  25. blowby
    blowby
    from Nicasio Ca
    I searched it a couple days ago, popped right up on the first page.
    I might consider a checkerboard on my heap but I would paint the firewall black and cut some white squares out of contact paper so I could peel them off if I got tired of it.
  26. hotrodjack33
    hotrodjack33
    Hey Lloyd, that DOES make slightly more sense than my version:eek:. And the picture helps keep it in context...otherwise it sounds like a case of domestic violence. Keep the ***** Floored, then...KHDA...Knock Her Down Again;)
  27. Hnstray
    Hnstray
    from Quincy, IL
    An old weather related pilot maxim.....”I’d rather be down here, wishing I was up there, than up there wishing I was down here” :D
    Ray
    Dino 64 and oj like this.
  28. lothiandon1940
    lothiandon1940
    ..............Now we're talkin'. I might humbly recommend Wimbledon White.:D
  29. Stan Back
    Stan Back
    Kinda makes the firewall the focal point of the whole car. Is that what you want?
  30. hotrodjack33
    hotrodjack33
    I have to admit my checkerboard firewall was one of those "sounded like a good idea at the time" endeavors. When I finish painting and removed the tape, I realized it was just a little too much:(
    I had the choice of sanding it off and re-shooting the firewall flat black again...or I could try to learn to live with it.
    Slacker that I am...I chose the latter:D
    Hnstray and lothiandon1940 like this.
