chev 265 balancer pulley change
Discussion in 'The Hokey Ass Message Board' started by Jeff J, Dec 5, 2012.
  1. Jeff J
    Jeff J
    The pulley is riveted on to the balancer and I need to put a 3 pulley system on it . Looked on the form but couldn't find anything. Any ideas? Thinking about drilling out the rivets and and tap in bolt holes ! Any body done this before ? This is on a early 265 chev motor, said date is 05-1955 Thank you in advance !
  2. Rocky
    Rocky
    Classified Editor
    I'd use a later dampener with the 3 bolt pulley.
  3. landseaandair
    landseaandair
    from phoenix
    X2 on replacing it but there most likely arent any threads in the crank which could make installing a pain, and if you plan on stacking a bunch of accessories on there, the lack of a bolt could mean spinning the balancer on the crank eventually.
  4. BOOB
    BOOB
    from Taylor, TX
    Later balancers are not the press (or hammer) type and the snout is longer. I would tap the holes.
  5. landseaandair
    landseaandair
    from phoenix
    Pretty sure the holes would nowhere near line up and the center of the 265 has a raised center register. Probably easier to whip up a pilot tool and drill and tap the crank.
  6. BOOB
    BOOB
    from Taylor, TX
    I've looked in to that. I've been scared to try it myself. Id like to put an SFE balancer on my 265.
  7. vtwhead
    vtwhead
    I just drilled out the crank on a 58 283. Was not a bad deal at all. It was on the engine stand so that made it a tad bit easier. I taped a welding rod on the top of the snout as a guide to make sure I stayed plumb and level. Tapping it out to 7/16 was a little slow but took my time and it went quite well.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
  9. Rocky
    Rocky
    Classified Editor
    Yeah, the later SBCs all used a press-fit balancer. When chevy began using the big diameter balancers, they drilled and tapped the crank snout but they still have to be pressed on and off..
    Use a common 283/307 balancer with a bolt-on pulley.
  10. 325w
    325w
    I had a 57 that the rivets came loose on. It had three holes to install a puller. I put three bolts in it and stop the loose rivets. Why can't you bolt a different set of pulleys on there.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If memory serves me well, there's only 2 holes on the 55 balancer.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
  13. BOOB
    BOOB
    from Taylor, TX
    I'm learning. I understood the early balancers had a shorter snout/shank/collar (whatever you want to call it) than the later. Also, I understood the early cranks have a shorter distance from the tip of the crank to the step for the crank sprocket, limiting them to early balancers. If the inside specs are identical between the two balancers I guess you could machine the snout down? It's been years since I've researched this but I talked to a few guys that ordered aftermarket balancers for the early sbc's and they didnt fit although summit claimed they would. They ended up having them rebuilt. Can someone confirm from personal experience that an aftermarket balancer is available? I would love one
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ ****, the difference may only be 1/8" or less, but that's only a guess on my part. The 265's had a oil sling washer that fit between the lower timing gear and the snout of the balancer.
  15. BOOB
    BOOB
    from Taylor, TX
    I'll step out to the shop when I get home and take a look. I have a few of each. I'll let you know.
  16. BOOB
    BOOB
    from Taylor, TX
    Turns out all my late model balancers are on motors, i dont have time to pull them just yet. Maybe tomorrow. But, I have the balancer off a '56 265 which I believe is identical to a '55. The total length of the snout is 1.1" and the distance from the tip to where the seal sits is about 0.5".
  17. Jeff J
    Jeff J
    Thanks for the info **** . And there are only 2 holes in the 55 balancer and it is a rivet on pulley. It would be nice if the balancer from Summit would fit ! Anybody out there use the one from Summit ?
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It will fit Jeff, go back and open the link and scroll down just a small bit. You will see that it fit's 55-57 265. All you really need is a later basic 283 307 balancer. Those are cheaper than the one I posted on the link.
  19. smithjenife
    smithjenife
    from new york
    I would tap the holes.[​IMG][​IMG][​IMG][​IMG][​IMG]
  20. Jeff J
    Jeff J
    No pics Smithjenife This is what I got !!!!
  21. Jeff J
    Jeff J
    Had to drill and tap the crank,7/16-20 to put the balancer on but it works and wasn't that hard ! Thanks all for the help. Got a balancer for $60.00 brand new from a engine shop and bolted right on, Pulleys line up . Ready to finsh the a/c
  22. landseaandair
    landseaandair
    from phoenix
  23. BOOB
    BOOB
    from Taylor, TX
    No ****! Whats the part number?
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    All right Jeff!
  25. Jeff J
    Jeff J
    Here's the number **** !!!! Part number i s 8000
    Thanks again Johnny Gee .
  26. Since changing pulley weight is straying from the overall designed weight (m***) of the finished ***embly for that particular engine, should one remove material (in a balanced process) from the balancer itself to offset the added weight of the larger pulley m***? I know that a lot of that goes out the window anyway because the engines we play with are far from stock but I often wonder when someone shears one off when racing if that isn't the reason. http://en.wikipedia.org/wiki/Harmonic_balancer
    PS Really nice 55!
  27. Jeff J
    Jeff J
    I think this would be the quote "**** Happens" :eek:
  28. Jeff J
    Jeff J
    Just a little help on some brackets to make fit on a 265 chevrolet with stock exhaust manifolds. A little modification to the alternater bracket and make new spacers for both sides and it bolts up . The alt. bracket have to cut a little area( see pic ) to clear the manifold and make (4)- 1 3/4" spacers and it will bolt up easy to the manifolds. The a/c bracket you just have to use the other 2- (1 3/4") spacers you made that go between the bracket and the exhaust manifold and it bolts right up . Have the brackets painted right now will post later ! :cool:
  29. Thanks for the drawings. Info. I'll be using.:)
  30. Jeff J
    Jeff J
    Forgot to post this of the drawing gives you demensions of the cut out !
