Chev 350 trany
Discussion in 'The Hokey Ass Message Board' started by tapkoote, Aug 12, 2013.
  1. tapkoote
    tapkoote
    Looking at a car for sale, cruiser w/ small block350 & 350
    trany.
    Don't know much about these , does this statement seem right to you folks?
    -turbo 350
    One should remember that the TH 350 was designed for lower torque applications, and as such has some weak points when compared to the TH 400. The first weak point is excessive end-play between the pump and center support and use of a relatively narrow bushing in the drum, both of which can result in wobble of the direct clutch drum. This weak point can be addressed by using an extra thrust washer between the planetary gear and direct clutch by and using a wider aftermarket bushing in the direct clutch drum. Another weak point is the relatively thin center support and the lightweight matching splines in the case. This weakness can be addressed by using an inexpensive aftermarket case saver kit.
    Fixing these two issues will result in a TH 350 that is nearly as durable and reliable as a TH 400.
    If I get it It wont get beat too bad.
    Pat
  2. hoop98
    hoop98
    from Texas
    A properly ***embled Turbo 350 will have no issues under 400 ft pounds and normal use. It can be built to take more and be very durable. A TH400 i a great transmission but with today's components the TH350 can be a lighter alternative.
    I wouldn't want a TH400 behind a V6 Le Regal or a TH350 in a 455 Estate wagon with a Cl*** 3 hitch. Horses for courses.
  3. saltflats
    saltflats
    from Missouri
    You forgot the harden intermediate overrun roller clutch race.
  4. tapkoote
    tapkoote
    Don't use em west of the rockies:eek:
  5. tfeverfred
    tfeverfred
    If all that was in the ad, the guy sure covered his ****. I'd almost be afraid something was wrong with it.
  6. chubbie
    chubbie
    not sure whats going on here, are you saying you don't know much about a 350 turbo? and then a long winded speech on the faults???
  7. tapkoote
    tapkoote
    Hey guys
    I got that quote from a web site,( wild about cars.com) when I looked for the diff between 350 and 400 trany's.
    Couldn't find the right comparison here.
    I'm an old FNG looking for a driver work on project.
  8. elba
    elba
    I have built over 200 TH 350's. They are excellent transmissions.
  9. txturbo
    txturbo
    They used them forever....good Trans for a street car.
  10. thebronc4019
    thebronc4019
    from New Jersey
    I have had a built one behind a 383 stroker motor that goes 10:74 @126 through the mufflers for years and have never had an issue. Car weighs 3000 pounds
  11. birdman42
    birdman42
    Every trans has its weak points. 350s are great transmissions it sounds like his has problems.
  12. GassersGarage
    GassersGarage
    Man, I had an A-1 Turbo 400 with a manual reverse valve body and I couldn't give it away. Everybody wanted a 350th. Finally a guy with a suburban took it off my hands. Funny, he didn't want the 5000 stall converter. LOL
  13. mustang6147
    mustang6147
    from Kent, Ohio
    Well if your putting ****** against ******. There are other models that make the 400 look weak...
    The question is what are you putting the ****** in? or what it in?
    You don't need a nuclear power plant behind your camper to charge the batteries....
    The 400 also takes more HP to operate it....
    SO I am wondering, What are you putting the ****** in? or whats it in??? As far as I am concerned, using the fact that the car has a 350 instead of a 400 is not a leverage point for negotiating.
  14. Gman0046
    Gman0046
    I've had numerous 350TH transmissions and never had a problem. I consider them almost bullet proof.
