Hello Everyone- i am new here - curious as to if anyone has knowledge on putting Disc Brakes on a chev 1967 g10 van?? Has factory straight front axle.Brackets? kits?? Interchange info?? Thanx,matt
Matt, It has been covered many times on Chevy Talk website. I ***ume a van would be the same as a truck but your best bet is to find a donar and just grab the axle and all. They will tell you what years (I think it was 72-85), but it is pretty much a bolt up. You may have to drill one hole on each side of your framerails, the other four will line up. Make sure you get the power brake booster and proportioning valve from the donar too and you might want to look at the power steering unit, if you don't have one. It's sounds like a lot, but it really is an easy thing. Good luck! Kathy
