Chev SB Engine Decode.. Odd Numbers
Discussion in 'The Hokey Ass Message Board' started by goleafsgo_12, May 19, 2011.
  1. Here are the codes from my engine that I recently acquired... Something doesn't match up with the date codes though, It seems like there is 1 too many numbers. The same goes for the engine stamped ID code, that has way too many numbers and no letters.. Any details would be appreciated! Thanks
    Head casting: 3795896
    Markings: N and M (embossed, in a square right beneath the casting #) No typical date stamp.
    Manifold Casting: 3844457
    Date: F2063
    Markings: GM 2 T
    Block Casting: 3782870
    Date: H2763
    Markings: 4T
    Stamped ID: 854620328 (Note: “28” were stamped darker then the rest, may have been non-factory)
  2. cowboyinachair
    cowboyinachair
    from colorado
    block is 64-67 302 327 350 210-350 hp 2 bolt truck and p*** block
    cant find the other numbers
  3. AAFD
    AAFD
    from US of A
    '63 327, would have to dig through the books to get the rest of the info.
  4. Deuces
    Deuces
  5. cowboyinachair
    cowboyinachair
    from colorado
    3795896....62-64...327......60cc chamber
  6. Thanks guys. I've got that far 62-67 327 etc etc, but its the date and stamped ID numbers that are throwing me off, any thoughts on them? The fact that both the block and manifold ends in 63 leads me to beleive that its a 1963 (hence 62-67), and the heads are apparently from 62-64 corvette (provided its 327, not 283)
  7. cowboyinachair
    cowboyinachair
    from colorado
    i have seen id numbers changed by michine shops not sure on the other
  8. Novadude55
    Novadude55
    from CA
  9. squirrel
    the casting dates are from summer 1963. I don't have any idea about the stamped engine number, must be a canadian thing.
  10. Thanks for the help guys. I'll have to measure the deck height to see if the block has been milled, it's probably a home-stamping jobby by the previous owner as that amount of numbers doesn't relate to anything, even VIN numbers.. and the fact it was pre-1968 means there wouldn't be any VIN id anyways..
    Thanks!
  11. Canadian Pontiacs used small block chevys and the numbers are kind of haywire. Yes, it is a Canadian thing.
  12. Mr48chev
    Doing a google search on the head casting number on the heads show that they are what most of us call power pack heads. http://www.chevytech.info/3c3795896.html
    Or just Google 3795896 and the results will show up. Fair to middling mild street heads but they aren't Corvette heads.
    It looks like the engine was originally a lower performance 327. Not a bad thing though.
    What I can't understand is why be so **** about date codes and everything if the engine is for a hot rod? Maybe if you are building a 63 or 64 Impala to a 100 point Restoration that is intended to compete in restored Chevy shows against other numbers date matching cars. Parts wise it's a 63 327 with 1.72 power pack heads if you are hunting parts.
  13. Deuces
    Deuces
    Yeah! .... Like the rare Canadian 4-bolt main 305 block... First time I've heard of it!
  14. It's not that I'm being **** about a 100 point resto, just curious to see the history of what I'm working with, where it was from, when, etc.. More of an interest thing than anything else. The value of the motor would be far greater as well if it were to spec out as vette. One site had those numbers down as vette heads between 62/64.
