Technical Chevrolet 1954 positive camber issue
Discussion in 'The Hokey Ass Message Board' started by Acres, Jun 18, 2024.
  1. Acres
    Acres
    from Sweden
    After i replaced all of the wornout stuff in the front suspension i started to notice some unusual tirewear on the right front tire, on the outer edge.
    Plan were to take it for an alignment but I bought a cheap Camber tool just to check how bad i was and make some rough adjustments by myself.
    Right front got around 3.5 positive camber.
    I have tried to adjust the excenter but its just gets worse.
    One thing I think is strange, when the jacking up the car, wheels hanging free in the air, I get the reading 1 negative camber.
    I were sure if lowering a car would get more negative camber, I got the opposite.
    Pulling my hair here, cant se anything bent, frame and front suspension looks fine.
    Are there any other way adjusting Camber?
    Are the spindle upside down? Grease fittings facing forward.
    The steering had so much play before so the tires were wobbling quite good so I guess The Camber angle were much better back then.
    All help is appriciated
    Sharpone likes this.
  2. JohnLewis
    JohnLewis
    From the 49-54 supplement manual, don't know if that will help you or not.
    tractorguy likes this.
  3. jaracer
    jaracer
    On most independent front suspension, the camber goes positive as the ride height is lowered. However, you seem to have a lot of positive camber. How is the other side?
    Acres and tractorguy like this.
  4. rockable
    rockable
    Look at your control arms closely. Has the lower control arm been bent?
  5. Bob Lowry
    Bob Lowry
  6. Acres
    Acres
    from Sweden
    The left side is ok.
  7. Acres
    Acres
    from Sweden
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Never rebuild that era front end so I’ll ask. Do the lower shafts have an offset? as well can they bolt up either way if they do?
  9. Acres
    Acres
    from Sweden
    The lower shafts do not have any offset or excenter
  10. Acres
    Acres
    from Sweden
    yesterday i replaced the lower controlarm just too be sure, didnt change anything
  11. rockable
    rockable
    How about the crossmember? It didn't come that way. Something changed.
  12. Bob Lowry
    Bob Lowry
    Yep, sorry, these are typically used for MORE camber....however, if you put them in with the thick end
    towards the front, I wonder if it would reduce your camber.? Please let us know how you solve it. Bob
  13. jaracer
    jaracer
    That points to something bent, badly worn, or put together wrong on the right side.
