Chevrolet 216 split manifold
Discussion in 'The Hokey Ass Message Board' started by fishman1, Jul 25, 2009.
  1. fishman1
    fishman1
    How do you split a 216 manifold?
  2. greaseguns
    greaseguns
    Weld a block plate into the rear of the heat rise box,then cut hole in rear underside of manifold and weld on another exhaust dump.
  3. fishman1
    fishman1
  4. retromotors
    retromotors
  5. BM1Retired
    BM1Retired
    from Missouri
    Get someone that knows how to weld cast. Just had my split manifold repaired, the old weld broke, actually the part that was on the manifold was rusty looking. Make sure it's clean, sanblast and even grind down where the weld will be for a good bind.
  6. 2manyprojects
    2manyprojects
  7. kustomclassics
    kustomclassics
    hole saw,that's what I use but I make my hole on the side instead of underneath.
